I got a ZTE N860 03.16 that I just can't get to facory reset no matter what I do. Its a boost mobile phone and boots up into android 2.3 and has never been messed with or rooted. I've tried all the different combinations of buttons I've seen on the web and none of them work, I've also tried resetting the phone threw privacy in the settings menu and nothing. I get the same result no matter which method I try, It gets stuck on the android when booting up and doesn't move from there. I've also tried downloading a number of different rooting tools to try and flash it back to factory defaults and nothing. Any help besides telling me to call boost would be appreciated.
SOURCE: ZTE N762 Reset
Menu>Apps>Gallery>Themes>Scroll to Theme that you want to delete and press options>Delete
After that you select and hold the application which you wish to delete
and..."
Here is what you have to do in order to delete/remove/uninstall (call it
whatever you want) themes from your Nokia C5-03: Menu - Settings -
Application Mgr. - Installed applications - then you will see the
installed app. in your phone, after that you SELECT and HOLD the
application which you wish to delete and after you do that a Pop-Up wish
appear written UNINSTALL in it, you then select Uninstall - YES and the
application will be removed from your phone. Use the same way to delete
songs too, just SELECT AND HOLD the song you wish to delete and the
pop-up will appear, you then should click DELETE and job done ;) Hope i
was clear on this explanation and wishing this will help you!
SOURCE: Unable to reset ZTE N762 phone
Hi,most smart phone has app's that comes with programs that protect your phone ,like your compurtor,It has to have a security I have a LG . One of my app's is a security app, call lookout and one section has a restoer,and backup, If you go to setting it might work, or juet pull da,/batt;and let it for a few.put, batt;/back in.
turn phone off , then hold the up volume button an the on/off butoon together wait till the android comes up let go then a blue an black screen shows up use the volume button to scroll an the power to accept, so scroll down to what u want to do to ur phone, good luck I never had a problem doing this to any phone always works
