I have a saeco Magic Deluxe. I got it second hand and it has been working fine to about 6 months. Now it does not complete the brewing process. It either starts brewing and dispenses a small amount of coffee prematurely stopping and ejecting the grounds or it grinds and prepares to dispense before reseting itself and empties dry coffee grounds. Can get steam and hot water just no coffee.
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
My machine is doing the same thing. It runs fine for about 3/4 of the cycle then resets. It stops about 2 red lights before the top. Did you figure out the problem?
I have tried reprogramming, adjusting the grind, changing the dosing amount and using the preground function. All produced similar results.
The machine will prebrew and then dispense for anywhere from 2 - 5 seconds and then the panel will reset and the grounds will be ejected. This will happen even when reprogramming, although it will probably run a few seconds longer. Sometimes while reprogramming i can get about 30ml before it resets.
Sorry in respone to your question, the pump stops when the panel resets
