Electrolux EIED55I Dryer Logo
Question about Electrolux EIED55I Dryer
My electrolux drey will not turn on or light up
After a power outage. All the lights on the range are blinking/flashing, how do I turn them off? Everything still works. Just can't turn off lights.
Hey Scott, I understand that you are having problems with your Electrolux Dual-fuel Range. When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
What does it mean when my electrolux 2100 vacuum's protection light is on and the vacumm won't start
hellllllllo.......in short....youtube....."is your electrolux not turning on" [a] bag sensor [b]carbon build up............tkx....g.scott
Sep 25, 2014 • Vacuums
Electrolux Dishwasher model EIDW6105GS1A, heavy light on, won't start. Turned off circuit breaker for dichwasher and the light turned back on and it won't start still. No lights on behind kickboard to show...
Good Morning Kim,
I see that the heavy light is staying lit on your Electrolux dishwasher, model# EIDW6105GS1QA, even after resetting your appliance at the circuit breaker. I also see that there are no lights lit up behind the kickboard, indicating what might be failing. It could possibly be the control board underneath your dishwasher. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing the heavy light to stay lit. I hope this is helpful.
-Best Regards-
WP
3helpful
Electrolux Precision vacuum brushes stopped turning and a red light turned on
there's a reset button down on left side of powerhead in the black plastic at base that corrects the problem of that red light
Amp promblems
When hooking up an amp a remote wire has to be ran. It is possible to jump the remote from the power wire, but if you do this the amp will not shut off unless you disconnect it. If this is done on your amp your battery will continue to die. Also, most cd players have a remote connection. Check to see where your amp remote is running to.
6helpful
2answers
Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
Top Electrolux Dryers Experts
vince
NOEL
NOEL
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
