Krups Ea9000 Barista Espresso Machine Logo
A
Anonymous Posted on Mar 04, 2014
Unschedules maintence The machine goes into a schedules maintenance cycle in the middle of making an espresso or cappicino, ruining the drink in progress
Louis F Hoholek Jr
Level 3:
  • Master 1,140 Answers
  • Posted on Nov 30, 2015
Louis F Hoholek Jr
Master
Level 3:
Answers
1140
Questions
0
Helped
259114
Points
4510
Defective electronic components.
2answers
Cimbali m1 locked out
Machine might have calling for a clean cycle for a while, if it does not get one it lock up until cleaned.
Carry out maintenance
1. Perform cleaning cycle.
2. if machine does not clear then it time for Scheduled service. (powering down machine won't reset this warning)
My maintance light comes on is there a "do it yourself for this"? my care is a honda civic hatchback si.
Just to be clear, your maintenance light has illuminated and not the check engine light (CEL) . a CEL indicates that the car has detected a problem of some kind and depending on the severity of the fault it may be harmful to continue driving.
If it is the maintence light then that is easy. It is automatically set to come on at predetermined mileage marks to remind you to have the car serviced.
The maintenance required light is a reminder to bring the car in for scheduled maintenance (every 10,000 miles). The light will flash after start up for 10 seconds once you are 2000 miles from the car's scheduled maintenance. Once you pass the scheduled maintencance mark (every 10,000 miles) without having the maintenanced performed and/or the light reset by the dealer, it will remain on forever unless reset.
To reset it yourself
Hold down the trip meter button, turn the car to on, wait about 20 seconds, start the car, and let go of the button. Light is reset until the next mileage interval.
*make sure lo beam headlights are turned OFF during the procedure*
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_cd01d4e4178e5a11
Machine does not dispense milk properly
Hi
There is a pin in the cappucinator the needs to be turned slowly to create the venturi action to make it work. If you have lost the pin it won't work.
Saeco Primea Touch
If you use the milk feature, please make sure that you rinse after making a milk drink or the machine will automatically request a milk cleaning cycle which is different than a rinse. For example if you make a milk drink and you skip the rinse cycle and leave the machine without rinsing for more than 20 minutes it will schedule a mandatory milk cleaning cycle.
It is okay to skip milk rinsing if you are making drink after drink as long as you rinse after the last cup.
Hope this helps you out.
Saeco's First Authorized Service Center of New York
Cerini Coffee Services
www.CeriniCoffee.com
Solis Pallazzo espresso machine - need maintence manual
Hi, check under: http://www.solis.ch/franzoesisch/kundendienst/kundendienst_f.htm
and choose your machine, under E (english) column, you'll get the pdf.
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
