Question about D-Link DIR-615 Wireless Router
Connection other devices - D-Link DIR-615 Wireless Router
  • Anonymous232 Feb 02, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
How many devices can be connected via bluetooth
Hi Sam,
  • The official Bluetooth specifications state seven(7) is the maximum number of Bluetooth devices that can be connected at once.
  • However, three (3) to four (4) devices is a practical limit, depending on the types of devices and profiles used.
  • Some devices require more Bluetooth data, so they are more demanding than other devices. Data-intensive devices may reduce the total number of devices that can be active at the same time.
  • Some manufacturers may limit the number of Bluetooth connected Devices;
  • Price & Quality may also be a factor.
If a Bluetooth device becomes slow to connect or does not perform reliably, reduce the total number of connected devices.
GL,
JP
Jun 20, 2015 | Cell Phones
Can't connect to TV
Most connection problems that prevent streaming occur on the device itself, or on the home network. In a nutshell, we will have you test the Internet connection on the device, log out and back into Netflix, restart your device, and restart your home network equipment.
Select your device from the list below for steps tailored to your device:
  1. Test the Internet connection on your device
    Many devices have an application to test the Internet Connection. If not, try opening the application store or another Internet-enabled application and check if your device is able to reach Internet services.
    • If you are unable to connect to the Internet, you may be having network connection issues.
  2. Restart the device
    Restart your device by unplugging it from power for at least 10 seconds, then plug it back in and turn it on with the power button. Restarting the device is often enough to restore your ability to connect to our service.
    Note: All devices are different. Some may take up to 15 minutes to fully restart.
  3. Disconnect and Reconnect the Netflix application
    These instructions will work on most consumer electronic devices with the Netflix application.
    1. Launch the Netflix app.
    2. Using the arrows on your remote, enter the following sequence:
      • Up, Up, Down, Down, Left, Right, Left, Right, Up, Up, Up, Up
    3. Select Deactivate and exit the screen.
    4. Restart the Netflix app and sign in to your account.
  4. Troubleshoot your Internet Connection
Oct 07, 2013 | Netflix
My tomtom go 700 will not connect to my pc
The moment you connect your TomTom device to a computer, your device should ask Do you want to connect to 'computer'. Once you tap YES, it should connect to the computer. TomTom HOME then starts.
If your device is not connecting, click one of the solutions below:
Dec 27, 2010 | Tomtom GO 700 GPS Receiver
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
How do you connect bluetooth to a sony ericsson k610
let phone in menu /settings searts for bluthooth device and the device like for earpusch on buton the same time device phone wil see it select connect and put code in 0000 and device are connect
if you want connect to pc you need first bluethooth device on pc like usb blue thooth stick and on pc you need software this are for free from itv bluesoleil google for it and also syngr software from microsoft.
Nov 08, 2009 | Sony Ericsson K610i Cellular Phone
How do you connect a bluetooth device to your computer
If your PC doesnt have a bluetooth capability, you need to have a bluetooth dongle, this device is a USB plug and play,, in order for you to connect any bluetooth device to your PC.
Sep 18, 2009 | Gateway M305CRV Notebook
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
How to connect blue tooth from pc to samsung cameramobile?
hi there!
While the specific user interfaces implemented by manufacturers may differ from device to device, there are still some very basic steps to go through in connecting two devices for the first time. Users should always conduct the pairing process in a secure environment.
Charge the Devices
If the devices are new Bluetooth devices, often they must be charged before they can connect or turn on. This is particularly true of new Bluetooth headsets, which must be charged before use.
Power Up the Devices
Power up the devices you are trying to pair. With some devices, like Bluetooth wireless headsets, powering up the device also initiates the pairing process.
Turn the Bluetooth Functionality On
The Bluetooth functionality in a device may or may not be turned on when you receive the device. For many computers, users will need to turn the Bluetooth radio on from the control panel or system preferences.
Make the Devices Visible
As a security measure, some devices allow the Bluetooth functionality to be off, hidden, or visible. When trying to connect devices, users should make the devices visible so the devices can discover one another. After the devices are paired, users can set the devices to hidden if they have concerns about their devices being discovered by others.
Place Both Devices in the Connection Mode
After both devices are charged, powered up, and the Bluetooth functionality is turned on, each device needs to initiate a communication session. Typically, in a connection between two devices, one device acts as the “host” and the other device acts as the ”guest.” The device in the host role is the one with the user interface from which most of the connection setup will take place. A device can be in the host role with one device and in the guest role with another device. For example, in a phone and wireless headset pairing, the phone is the host. However, in a phone and laptop pairing, the laptop is the host.
Enter the Passcode
After the two devices have discovered one another, the user will be asked to enter in a passcode in one if not both of the devices. In some cases, like with wireless headsets, the passcode is a fixed passcode assigned to the headset by the manufacturer. In those cases, the user enters the assigned passcode into the host device. The user will find this passcode in the user manual. In other cases, the user will be able to enter in his/her own passcode. In these cases, the user will enter the passcode once into each device. It is highly recommended that users employ an eight character alphanumeric passcode for the one-time pairing process. After the passcode is entered, the devices will validate one another and complete the establishment of a trusted connection.
Deleting or Disconnecting Trusted Devices
When should a user delete or disconnect a trusted device? If one of your Bluetooth enabled devices is lost or stolen, you should unpair that device with all the devices to which it was previously paired.
How do you unpair or delete a trusted device? For devices like a mobile phone or computer, the user should go into the device connectivity settings and find the list of trusted devices. The user should then have the option of adding a new device or deleting a trusted device. Highlight the device you want to delete and push the delete button. A device like a keyboard or mouse, which only has a button or switch as a user interface, can only connect to one device at a time. To delete its previous trusted device, the mouse or keyboard just needs to be connected to a new device
Or you can try this:
Bluetooth Mobile Phone to Bluetooth Personal Computer
  1. Power up both the mobile phone and the personal computer.
  2. On the PC, open up the control panel and find the Bluetooth Device Wizard. This will assist the user in setting up a Bluetooth connection between the PC and trusted devices.
  3. Ensure the Bluetooth connectivity is turned on in the PC.
  4. Find the connectivity settings of the phone. Make sure Bluetooth connectivity is on and visible.
  5. On the PC, choose to find and add a specific Bluetooth device.
  6. Of the devices found, pick the mobile phone with which to pair.
  7. PC will generate a PIN code.
  8. Mobile phone will ask if you wish to be connected to the PC.
  9. After the user answers in the affirmative, the user will be prompted for the PIN code on the mobile phone. Enter the PIN code into the mobile phone, which the PC generated.
  10. Allow devices to complete the establishment of a trusted link.
  11. If prompted on the PC to choose the Bluetooth services, the user may have several services available. The user may be able to sync the phone and PC. The user may be able to set up dial-up networking (DUN) preferences so that the user can use the mobile phone as a modem for the PC over the Bluetooth connection. The user may be able to transfer files, like pictures or business contacts, between the mobile phone and the laptop.
  12. After choosing which services the user wishes to enable, the user can then finish the connection and exit the setup on the PC.
better yet go to this website: http://www.bluetooth.com/Bluetooth/Products/Devices/Generic_Pairing_Instructions.htm
Feb 16, 2009 | Samsung SGH-E251 Mobile Phone - Black
D-Link DIR-615 Wireless Router Logo
55 people viewed this question
Top D-Link Computers & Internet Experts
Mike
Jeffrey Groves
Jeffrey Groves
RockTheHood
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
