Question about Sony KV-32FS13 TV
I have 21''sonymodel no kv-21L70 prblem of blinking 4 time the red light but not on the tv
HI 4TIME BLINKING NOT SHUTE DOWN AUTOMATILY WHAT IS THE PROBLEM
Posted by CHEGA WONDIFERAE on
5 Related Answers
Anonymous
  • 129 Answers
SOURCE: Sony Trinitron KV-27FS13
Good day.
Maybe there is a problem with eigther the vertical or horizontal circuitry of your unit. blinking lights indicate a problem associated with your flyback not being able to oscillate and distribute the supply for the tuner, audio, vertical...etc..
That is an internal problem pls refer to a qualified technician.
chris
Posted on Mar 23, 2008
Anonymous
  • 131 Answers
SOURCE: tv wont turn on -- stand by light just keeps blinking
This is very common problem for sony. Blinking light is power supply problem need to replace two voltage reulators in supply and caps and sometime horz output.
Sometimes if you adjust screen voltage adustment on flyback just slightly it will fix it.
cost if ps is 225.00
screen is 95.00
Thanks doctor video
Posted on May 18, 2008
ABRsvcs
  • 4234 Answers
SOURCE: fd trinitron wega kv-32fs120
This is a problem with the regulator circuit. If you are comfortable with soldfering, you should be able to repair this yourself. I'll look up the specific parts that require replacement.
Dan
Posted on May 23, 2008
mortworker
SOURCE: Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
My Sony KV36HS500 Trinitron is doing the same thing. Last night the next street over was hit by lightning. The "7" blink pattern was happening, so like the manual stated, unplug it for 4 hours. Which I did. The t.v. is back up and running fine. It's a nice t.v., better than the plasma I paid over a grand for, that's already shot. It's a good t.v. and good that Sony put in the stand by protection to prevent the t.v. from dying an unnecessary young death. Patience, don't rush it, unplug the t.v. and leave it sit. Also, don't use a power strip, that was my mistake, and unplug your t.v. if storms are in the area, I was too lazy to and now I had to deal with this, in 8 years, only twice did this happen. I'd buy another one tomorrow if they still made them.
Posted on Jun 15, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Posted on Oct 02, 2008
I HAVE SONY 21''TV NOT ON BLINK 4 TIME
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given
Mar 04, 2014 | Sony FD Trinitron WEGA KV-21CL10 21" TV
I have sony crt tv problem of 4 time blinking not stand by model no kv-21L70
Mar 04, 2014 | Sony FD Trinitron WEGA KV-32HS420 32" TV
No tv red blinking lights
Blinking of standby light are fault indications. How many times the standby light blinks at a time. Count it, and inform me.
Sep 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONYmodel # KP51WS500 tv work for 45 minutes then blankout with a blanking red light
How many times does the light blink in between pauses? Let me know and I will assist the blinking is an error code.
Aug 09, 2011 | Sony KP-51WS500 51" Rear Projection...
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Dan
Oct 02, 2008 | Sony KV-32FS13 TV
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Good day.
chris
Feb 17, 2008 | Sony KV-27FS13 27" TV
Red lite blinking
help mine is doing it also, 4 blinks, no power
if any gets it fixed or knows how please email me at
[email protected] thanks
Dec 27, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS13 TV Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
