Question about Cell Phones
My headset is grounded
I think i pushed too much my headset to my cellphone jack. when i removed the headset the speaker is not working anymore. when i play music i can't hear anything but everytime i put back the headset, the headset work well. whenever someone calls me, i can hear the ringtones ringing but when i pick up the phone, i can't hear anything unless i put back the headset.. what should i do?
Posted by blueheaven07 on
Anonymous
    Problem Solver:
  • 5 Answers
Pushing the jack hard may result in some connections pushed way off, and there is no contact to the speaker. Please see the nearest technician.
Posted on Jun 12, 2009
Iphone 4s sleep button, speaker, microphone, headset jack are not working
It probably fell onto the headphone jack and something got messed up there. That's a problem that you could maybe fix by taking it apart and reseating the button actuator. If it fell onto the button, it may have pushed the actuator farther into the phone. The button pushes down on another button inside that is part of the actuator module, so may have been pushed around.
Mar 27, 2014 | Cell Phones
Loose jack connection to speaker
It sounds like you need to get a new jack socket and replace it. It could be just a soldering problem. Especially if you have removed the plug a lot in the past.
Jan 06, 2018 | Edifier Audio Players & Recorders
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
How do i fix the volume because i do not have sound? my tv has no volume/sound. tried turning the tv up and down but still no sound
1 - hi
2 - check the jack for headset
- if you heard any sound with headset = your speakers are burned
3 - if you always use this jack for head set its maybe got problem = when push or pull the headset jack if you hear any sound from speakers your headset socket should change
4 - if you didnt hear any sound from both (speaker and headset) it means your ampilifire should repair
May 23, 2010 | Emerson CR202EM9 TV
No Sound from External Speakers....only from Headset plug.
Hi, had same problem.... unscrew the remote and carefully remove the back end part of the stereo-connector (very careful !) it consists of a very small switch which moves sideways..... this switch is stuck into headphone-modus. Reassemble and it will work again
Note that speakers will work if you remove the switch
Apr 19, 2010 | Creative Labs I-Trigue L3800 Computer...
Laptop speakers does not work, headset does
When you connect your headset in to the laptops 3,5 jack connection there is a little switch inside that socket.If you push in the jack it turns the pc-s speakers off.Probably that little switch is stuck,you can move around the jack to try to free the switch.No other explanation for this issue.
Jul 13, 2009 | Dell Inspiron 700M Notebook
Jabra bluetooth adapter A210
hi,
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
Headset sign
(Plz.read fully)
Hai friends,let me first inform u that how your nokia 6630 detects it's headset.
There are 13 connector pins at the boottom of yr cellphone.4 for usb connectivity,others for headset,mic,switch,antenna(not in order).
The first pin from left(plz. neglect the isolated pin near to the edge) is ground
(-ve) and the second one act as a sensor for detecting headset is connected.
When the normal headset jack is plugged in, it short circuits the ground pin
Aug 12, 2008 | Nokia 6630 Cellular Phone
Treo 755 not able to make calls
The only workarounds I've read about these issues is:
1. Plug in the headset again and pull it out crisply and see if that works. Another method I heard, is to stick a toothpick in there.
2. Using the OEM Treo mono headset, insert the jack fully into the socket, spin the jack in the socket 180-360 degrees and remove the jack with a quick jerk. If the socket is truly undamaged, this technique, often repeated, seems to enable the speaker.
3. Some report that the headphone jack adapters, 3.5 to 2.5mm, work for this as well, that has NOT been my experience.
4. VolumeCarePro will bypass the headset switch and is a software workaround.
5. Otherwise, the only way I've been able to 'resurrect' the speaker is by hard reset, and once it took two hard resets.
As a result, I do not use my headset jack on my Treo 755p at all any more.
Unfortunately, this is an area that Palm is aware of, but has done little to fix.
is a hard reset
Jan 27, 2008 | Palm Treo 755p Smartphone
How to wire a headset to stereo phone jack.
http://en.wikipedia.org/wiki/TRS_connector#Tip.2Fring.2Fsleeve_terminology
the table shows u what u need i think
Oct 25, 2007 | Cell Phones
Cell Phones Logo
Top Cell Phones Experts
ADMIN Canada
ADMIN Canada
Are you a Cell Phone Expert? Answer questions, earn points and help others
