If you press any button on the machine it beeps 3 times and does nothing but show the time date and fax status.
We can't enter the menu setup to change any settings - it just beeps.
However it does receive faxs it just won't let us send any.
By the way it is on a remote site so I'm relying on someone else to relay the info to me.
Press Menu/Set, 2, 4, 1.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
To print a report
1 Press Reports.
2 Press ? or ? to select the report you
want.
Press Menu/Set.
1Press Menu/Set, 0, 2.
2 Enter the last two digits of the year. Press Menu/Set.
3 Enter two digits for the month. Press Menu/Set.
(For example, enter 09 for September, or 10 for October.)
4 Enter two digits for the day. Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format. Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time whenever the machine is idle in Fax mode.
When the machine is in Sleep mode, the LCD shows Sleep. (See Sleep Time on page 2-8.)
Hopefully that worked correctly and solved your problem!
Hey just found that it's a stuck key. You have to tweak at all the keys, one of them is stuck even if it doesn't look like it.
