Camera is on! but blank screen when i turn it on !
My camera turns on. once it turns on it only shows the samsung logo then straight after it goes to a blank screen but is still on. how can i fix it. and the battery is full!
Re: camera is on! but blank screen when i turn it on !
Does it actually work? Does it take pictures? It may be that "liveview" is off-that is the screen you normally view on when taking your photos. Try using it and then playing your photos back and check if its woking. A mate of mine had that problem last week and thought her camera was broken!
1.completely turn off the pc
2. turn it on and as soon as you turn it on click on the F8 keyboard
3. once your doing that another menu should appear
4.click on PREVIOUS SETTINGS THAT WORKED
5.it will load back again if it persists run the steps above again
6. if it doesnt work and continues run the SAFE MODE
7. in safe mode click on start and type System restore and open it
8. select a restore point far away since the incident
9. let it work and restore once finished it will reboot and it should work..
10. if all of this didnt work than you have HARDWARE problems
Definately the DC. Try ensuring that the connections are properly made first, and if that fails, try wiping the laser lens (very carefully) and the disc with a smooth cloth.
When you turn your camera on to the right of the view screen is the menu button if you press the far right icon it should turn your display on and off.Refer to page 21 on your owners manual.
You've probably corrupted the firmware download. If the camera is still recognized by your PC then I'd try downloading the firmware again and try to load it again into the camera. I don't wish to upset you but corrupting the firmware can in some instances make the camera unusable.
Your manual should tell you if there's a reset and how to do it.
Don't forget the camera's firmware can also be upgraded by loading the update onto the memory card and running it from there.
GOOD LUCK
BMW
