Samsung SRP 350 Thermal Printer Logo
Question about Samsung SRP 350 Thermal Printer
Slow printer the printer is printing unusually slow
Canon laserjet 2900B Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer
Laser unit is faulty or poorly connected. You have to dismantle the device, check the connection to the laser/scanner unit and check its internal optical parts for displacement. Check the rotating mirror if it rotates freely. Apply oil on its axis if stuck - it goes out easily. Keep the optical parts clean. If everything looks good, then the laser diode is faulty, or the light detector is faulty. In this case the printer needs new laser scanner unit. Unfortunately it is either too expensive or non-deliverable. The printer is quite old and slow model. Windows 10 is unusually slow printing to it. Over all this I recommend to replace the entire printer. https://printcopy.info/?l=en&mod=pc&brand=Canon&model=LBP2900&page=3
tip
10 reasons why PCs crash-You must know tip 7
7 Printers
The action of sending a document to print creates a bigger file, often called a postscript file.
Printers have only a small amount of memory, called a buffer. This can be easily overloaded. Printing a document also uses a considerable amount of CPU power. This will also slow down the computer's performance.
If the printer is trying to print unusual characters, these might not be recognised, and can crash the computer. Sometimes printers will not recover from a crash because of confusion in the buffer. A good way to clear the buffer is to unplug the printer for ten seconds. Booting up from a powerless state, also called a cold boot, will restore the printer's default settings and you may be able to carry on.
on Mar 04, 2010 • Computers & Internet
2answers
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
2answers
Why does processing job take long?
the print file detail may be multi-layered may be too much information in print job- your printer memory may not be adequate, you may be printing through a slow network, you may be printing through an older print server which is as slow as parallel port printing or you may be printing through your parallel port which is slow.
Printer won't print
What kind of printer is it (Model Number/Brand? Did it work before? Is it making any unusual sounds? Need more information.
Printing in color on my Lexmark printer is very slow. This is a wireless printer and is not so slow on black and white printing.
Printing in color is always slow vs. printing in B/W. If your printing color with the highest resolution setting, it will print really slow. You can adjust the resolution settings in Printer Properties for the Lexmark. If you want faster print, select a lower resolution.
It prints really really slow
Expect pictures to print slow no matter what.
For letters and all text documents set your printer up to print draft for the best printing speed.
Labels are slow on printing req to go faster
By the sound of it you are printing via the serial port, slow printing is normal for the Eltron (EPL) base printers
Paper feed problem
try a test print first, from control panel/printers
http://tinyurl.com/6qcpgy
Top Samsung Office Equipment & Supplies Experts
Gary
Gary
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
