Question about Canon DR-7580
Scanning half a page
It only scanning half of each page
Steve Garthe
    New Friend:
  • 78 Answers
You will need to check your page settings. As each program is different, the page setup will generally stay the same. It will also change if you are scanning at 0, 90, 180, or 270 degrees as well.
Posted on Aug 25, 2014
Scanning one side Only
Flatbed scanners scan one side only.
To scan the other side you would have to flip the page.
Dual side simultaneous scanners are rather rear.
Apr 21, 2016 | Office Equipment & Supplies
Canon DR-2580C scanner only scanning half the page. What could be the problem?
Select Auto for page size. The scanning software displays scanned image in many options, including 'fit'. Choose 'fit' so that you see complete image.
S. Mohan
Dec 29, 2011 | Canon DR-2580C Path-Through Scanner
Black lines on scan
Dear all
I have the same problem Please Help
Mark
Jun 04, 2010 | HP ScanJet 2300C Flatbed Scanner
Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
My hp officejet 6500 will not print pdf files . A single blank page comes out but nothing else.
have scanned records into my computer via hp officejet 6500 scanning software. when i come to print i only get the top half of the document printed on the bottom half of the page - help!!!
Oct 27, 2009 | HP Officejet 6500 Wireless All-in-One...
Half of the page is black. This happens during
Is this a printer or MFP? If it copies and scans then your problem is in the scanner area, either something is on the glass or you have a bad CCD (changes image into bits to write info to drum) let me know if this is a 8100DN or what and I will find more info on the scanning section.
Aug 06, 2009 | HP LaserJet 8100 Printer
Not scanning full page Canon DR-3080II/CapturePerfect
U should select 'Scanners maximum'  and try this. I have found this does not work midway, after some scans. So close and exit out of captureperfect, re-enter and try. This should work.
S. Mohan
Nov 19, 2008 | Canon DR-9080C Path-Through Scanner
Scan and print problem
A.PLEASE TRY CLEANING THE CIS SCANNING UNIT.. HAPPY PRINTING OMNIPRSENT
Sep 05, 2007 | Samsung SCX-4100 All-In-One Laser Printer
210 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
