Minolta bizhub 200 All-In-One Printer Logo
A
Anonymous Posted on Mar 04, 2014
Konica minolta c2556 - Minolta bizhub 200 All-In-One Printer
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Minolta Master 1,449 Answers
  • Posted on Jul 17, 2014
Minolta Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614262
Points
3628
C2556 Abnormally high toner
density detected yellow
TCR sensor
• TC ratio in the developing machine, which is
determined by toner replenishing amount
control mechanism, is 11 % or more for a
given number of times consecutively.
• When the connector of the TCR sensor is
disconnecte
After adding yellow developer in bizhub c360, the machine immediately start to give an error code of c2556 what is the problem and how to fix this... I real need your answer(shekinah.il1992@gmail.).
by adding manual developer, value changed, so try to reset many times and meanwhile add toner from service mode.
else need to change developing sensor chip
Konica minolta bizhub C253 is showing me trouble code C- 2556. What should I do to pix this problem
Konica-Minolta bizhub C253 Trouble Error Codes List page 4
Code C2556
Abnormally high toner density detected yellow TCR sensor
• TC ratio in the developing machine, which is determined by toner replenishing amount control mechanism, is 11 % or more for a given number of times consecutively. • When the connector of the TCR sensor is disconnected.
Solution:
1 Reinstall imaging unit. 2 Reinstall toner cartridge. 3 M3, M4 operation check (At this time, IU must be non-installation.). 4 Change imaging unit. 5 Change PRCB
Extract from:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C253&page=4
Error c2556
replace the yellow image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Error code C2556 Konica C652
Because that model does not have them, it is all electronic the sensor are in the image units
3helpful
Error c2556 in konica minolta bizhub c 200
C - 2556 Abnormally high toner density detected yellow TCR sensor.
Clean the TCR sensor window on the underside of the yellow imaging unit if dirty.Reinstall imaging unit or change imaging unit.
7helpful
2answers
Konica bizhub 250 error c255c
there is no c255c code but if it is a c2555 c2556 c2557 or any other c255 code it may need a new image unit. please give more info
1helpful
Error c2556
Just take out the yellow toner and bang it about for a bit, then put it back in. If this doesn't cure the problem replace the yellow toner.
15helpful
2answers
Error code c-2556
change the drum and the developer, clear the counter and run F8 function
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
