Question about Andis T-Outliner Hair Trimmer
Andis t outliner is making a loud noise someone help please?
I live in the uk and brought andis t outliners from the us and its making a loud rattling noise i have not used the trimmers just turned it on to see what its like i brought a plug converter or 110v ive twisted the screw like it says on youtube and it still makes the loud noise can someone help please?
Posted by jade swaby on
  • this style of clipper can be a bit noisy in any case, check to make sure the blade is atatched correctly by reading the instructions, do they cut ok?
  • Vibz v
    Vibz v Jan 01, 2015
    Hi, its because in america they use a different frequency. In the uk here we use 230v 50hz and Americans use 110v and 60 hz. So you've converted voltage but not the frequency. So what you need is a voltage AND frequency converter. Like thishttp://www.ebay.co.uk/itm/261718719033?s...
heidi muehlenberg
  • 62 Answers
This unit will not work correctly in the UK as it has a magnetic motor. No matter how you try to tune it it will be very loud and eventually the motor will burn out.
Posted on May 20, 2014
5 Related Answers
Anonymous
SOURCE: andis t outliner
Yes because I was about to just purchase a brand new device.
Posted on Sep 01, 2008
Anonymous
  • 61 Answers
SOURCE: andis outliner
you should not have to send your clipper to be repaired before it is used, the maker of the product should be willing to walk you through the adjustment step by step, because the problem is the blade adjustment,why send a clipper back just to get a blade adjustment,which will take 30 days to return,and you will be out of a clipper,you will lose money in the process, it's simple call and ask how to (precisely) adjust blade, and if that dosent work for whatever reason, return the product and buy from another company, some companies have a way of making more money from you,unnessasarily, in this economy thats a sure way to loose business.
Posted on Jan 28, 2009
Anonymous
SOURCE: i leave in uk i got a new t-outliner from us and i
Voltage & Frequency Converter
Posted on Mar 21, 2011
Anonymous
SOURCE: my andis T-outliner is makeing a loud noise
The problem you describe is most likely due to the fact that the machine you bought is designed to operate on 110v/60Hz electrical supply as used in North America. In fact the T-Outliner is only designed to operate on 110v/60Hz so even if you use a transformer you will only convert the voltage from 110v to 230v. You will not convert the frequency 'Hz' from 60Hz to 50Hz which is necessary with an electrical product with many moving parts such as a clipper to operate correctly on the European electrical supply which is 230v/50Hz........Check on ebay 'Voltage and Frequency Converter' about 65 pounds. The only solution
Anonymous
  • 8 Answers
SOURCE: I brought the andis speedmaster with the pivotpro
Some outliners have an adjustable blade set while others are fixed. You will need to remove the blade set and observe if the movable blade is adjustable forward and backward in relation to the stationary blade. If it is adjustable, take caution no to adjust the two blades completely flush. If they are too close they will nip and pinch and can break the skin.
Posted on Apr 10, 2011
My new andis t outliner making a loud noise
The Andis T-Outliner that you purchase from the USA is not for UK voltage 220 50 HZ, the Voltage is too high, the only way to control the voltage is transformer from 220V to 120 V. The Andis Trimmer that may work for you is the GTX trimmer this trimmer was manufactured for Canada and there voltage is 220V 50HZ.
Manny's Sharpening 323 237-2885 f175053b-23eb-4546-bbc5-bb86bc86dcf9.jpg Manny Mobile Sharpening and Clipper Parts Supplies
Mar 04, 2014 | Andis T-Outliner Hair Trimmer
My andis T-outliner is makeing a loud noise
Nov 20, 2009 | Andis T-Outliner Hair Trimmer
Andis t outliner
May 29, 2008 | Andis 04603 Hair Trimmer
I'm in the UK bought my
This trimmer is only made to be used with 110V, we do not have this model in 240V. There is no way to stop the noise. If you would like to purchase a unit made for 240V please call 1-800-558-9441 and speak with one of the Andis customer service reps.
Thank you for purchasing Andis.
Dec 01, 2007 | Andis Outliner II Hair Trimmer
Andis T-Outliner Hair Trimmer Logo
1,031 people viewed this question
Top Andis Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Marvin
Marvin
NOEL
NOEL
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
