39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
f white copies appear on your toshiba impression.
replace the corona wires main loading and transfer, do not forget to check the development unit if turevelador is too old replace
I'm having the same exact problem. I bought a Toshiba L2200U 50 inch and it works great with cable, but the DVD player only works in black and white. I've tried different DVD players and cables, but still no luck. Did you find a solution?
Black Screen with White bar is when Windows Vista loading. So it seems there is maybe problem with Windows. When your Toshiba is starting up - try press F12 to enter Bios, to check if everything is OK. If you have Vista on CD/DVD - you can try press "C" on keyboard when Toshiba start, to boot from CD/DVD and start to repair your OS, or reinstall it completely. Here - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/globalEntitlement.jsp you can find repair centre for Toshiba near you, so they can help you.
Support Contact Numbers: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/navShell.jsp?cf=su_contact&pf=true
Or use their forum http://laptopforums.toshiba.com/t5/System-Recovery-and-Recovery/bd-p/brd_recovery
check your scart connection, make sure its plugged in ok (silly i know but they do come loose and cause this kind of problem), also check in your video output menu that its set right, i.e. r.g.b, composite, pal, ntsc
It is not clear whether one DVD or all DVDs play in black and white. If it is only one make sure that the format of the DVD is correct. If it is all DVDs, given that the VHS tape and cable play with color, there could be a problem with the chroma circuit in the unit. This is probably something that a technician would need to diagnose. Good luck.
