Hi guys: I have a Konica Minolta Bizhub C252 I change from time to time for another one with less copies. I use to backup the settings and import them on the new machine. Always worked fine, until last machine. When I try to scan some sheets it create a PDF file for every sheet. I tried all differents configurations with no result. I think it can be a problem with the firmware version (this one could be older). Can anybody help me on the proccess of upgrading the firmware? Thanks in advance and excuse me about my english
SOURCE: konica minolta bizhub C252 printer Problem
It is supported for Vista according to this chart
Here is the drivers for 32 bit Vista
SOURCE: Konica Minolta bizhub C250 Scanned files
Try using the Comapct PDF option as a file type.
This should be used if file size is a concern.
It applies a mathematical compression so will affect the quality of the scans very little.
SOURCE: Konica Minolta bizhub 750 scan file type default settings PDF
Once you have selected PDF on the screen touch you Ulitly/Counter button, then select User settings, display settings, Scan Basic default.
can go to konicaminolta us web site and down load a operators manual for scan, copy, fax etc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
