Question about Sony FD Trinitron WEGA KV-32HS420 32" TV
I have sony crt tv problem of 4 time blinking not stand by model no kv-21L70
Posted by CHEGA WONDIFERAE on
    Top Expert:
  • Sony Master
  • 76,584 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given
Posted on Mar 05, 2014
5 Related Answers
ABRsvcs
  • 4234 Answers
SOURCE: SONY WEGA KV-36HS420 will not come on
The blinking is an indication that the set detected a problem. The code usually indicates a bad regulator circuit. If yu can solder, you can probably fix this your self. Please let me know if you wish to attempt the repair. If not, expect a parts cost in the $25-$40 range plus the local labor rate for the repair.
Posted on Oct 01, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Posted on Oct 02, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Posted on Dec 12, 2008
Anonymous
SOURCE: Wont turn on. There are 5 and 6 blinking stand by
my sony kv-34hs510 tv wont turn on.ther are 6 and7 blinnking stand by lights.
Posted on Jul 16, 2010
Anonymous
  • 6 Answers
SOURCE: Our Sony, wide screen, trinitron model number
you have to check you timinig on/off setting.
Posted on Aug 06, 2010
Sony tv model KV-HA21M80 is having problem front stand by L.E.D is blinking 4 times and stopping
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Electro help
Jan 14, 2015 | Sony Televison & Video
I have a sony tv model kv-27v42 i have sound but no pictture and stand by light blinks what is the problem
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 24, 2013 | Televison & Video
My tv kv-xr29m50 won'to on.stand-byl light blinks 8 time
Count the number of blinks occur at one time switch ON. These blinks are fault indications. After counting it, check this link for more details. There are details about Sony blinking codes. Search the site by brand name and model number to your TV in its search box.
Jan 29, 2013 | Sony FD Trinitron WEGA KV-13FS100 13" TV
I have sony 29'' crt tv . model no KV-DZM61 .when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 2 times .then the tv goes in stand by mode
2 blinks means - over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
Jun 23, 2011 | Sony KV-XR29M61 TV
SONY TV MODEL KV-27FS120 stand by light
if it is continous blinking.........then you have a faulty jungle IC IC301,shorted to ground,IK video path is defected,............ hope this helped
Feb 17, 2010 | Sony Televison & Video
Black screen model kv-27fs200 there is sound just no picture stand by light blinks 4 times the pauses and does it again
4 times standby light blink shows problem in vertical deflection section of TV.
Please check and replace vertical output IC in main board.
Thanks.
Dec 27, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32HS420 32" TV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
