A month or so ago the oven began beeping in the middle of the night. When I checked it, nothing would appear on the display and the oven didn't work. About 2-3 days later, it "magically" came back on and worked for a while again. Last week it went out again, only this time it showed an error code of E2 F6 (i think) on the display before it crapped out. Now it wont do anything and the display is blank again. Do I need to call for repair service or is this something I can quick fix myself. Help! I want my oven back!
Your oven temperature sensor has failed(e-2) as well as your electronic control board(f-6). The oven temp sensor, electronic control board and the touchpad must be replaced . Approximate cost of parts is $500.00. Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
We see this failure mode frequently. It is caused by multiple component failure in the electronic control board. Luckily, these can be repaired quickly and reliably. www.fixyourboard.com
