Question about Black & Decker Husky 750w Power Inverter
Black and Decker 750W inverter. Reverse cable hookup. Help to fix
Hooked up the cables in reverse. What would this blow? How can I fix this so it does not happen again? Big diodes in line with the main cables?
5 Related Answers
Anonymous
SOURCE: Black & Decker Drill (Motor does not work on Forward switch but it is ok on reverse)
Scraped the drill and bought a new one for $20
Posted on May 14, 2008
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Is this inverter powerful enough?
You are right. This is not enough to operate this freezer. You are going to need a bigger invertor it get it to work properly 900 or 1000 watt should be efficient even though it is not the best way to run the unit. If the unit has a problem you would be replacing the inverter all the time. Just FYI
Posted on Feb 20, 2009
#1 Taper
Jim Parker
  • 1041 Answers
SOURCE: threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Posted on Jun 21, 2009
Anonymous
SOURCE: Vector 2000 Max inverter VEC054D turns on, LED
sounds like my inverter im going to change the mofset or.triod it has 3 prongs.
Posted on Jul 27, 2009
Anonymous
  • 108 Answers
SOURCE: how do I change my black & decker electric
The switch near the trigger that toggles left or right controls that.
Good luck with your project, Kathleen.
Posted on Oct 11, 2009
I think i blew the fuse in my inverter by putting the cables on the wrong battery terminals--how to replace fuse
http://servicenet.blackanddecker.com/Parts/Search?searchedNumber=750%20Watt%20Power%20Inverter
There are around 8 models of the 750 watt inverter. The above web link takes you to the Black and Decker site where you can input your exact model number and then you can download the instruction manual which has the details for how to change the fuse.
Dec 28, 2010 | Black & Decker 750w Power Inverter
How to adjust low voltage cut off to lower setting about 9.0 volts
What is the normal low voltage cutoff?It converts AC to DC correct?Just comment and I will get an auto email that you did so and will reply ASAP.Greg
Aug 12, 2010 | Black & Decker Husky 750w Power Inverter
Reversed cables and blew a fuse. how do i get it out???
I think the needle nose pliers may be best. insted of grabbing by the thin sides, grab it the wide way and gently rock it back and forth. I think this is like a 35 amp fuse, so the holder has to be very tight to keep a good connection. I have one of these, and for two days I thought it was bad untill I pressed the red on button.
Jul 26, 2010 | Black & Decker 750w Power Inverter
How do I replace the fuses in a 750 watt black and decker power inverter
look for a cover to maybe flip up or slide (most inverters fuses are coverd)
Jul 05, 2009 | Black & Decker 750w Power Inverter
Connection to car battery
The answer is yes...BUT make sure the polarity is correct and the inverter turned off when you make the connection
Apr 30, 2009 | Black & Decker 750w Power Inverter
Feb 20, 2009 | Black & Decker Husky 750w Power Inverter
Where is the fuse(s)? What is correct replacement amperage?
Look for 3 - 40 amp fuses side by side near the fans, inside the unit
Jan 12, 2009 | Black & Decker Husky 750w Power Inverter
Black & Decker Husky 750w Power Inverter Logo
354 people viewed this question
Top Black & Decker Electronics - Others Experts
Sheldon Dedek
Vernon Taylor
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
