Question about Nokia 6630 Handheld
Operating system logging during i restart my cellphone?
Posted by ands on
Anonymous
  • 34 Answers
Can you tell me in a little detail
Posted on Oct 29, 2007
Reinstall windows vista
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
Feb 27, 2013 | Dell Dimension 4600 PC Desktop
How to install windows xp on a qss3300
If this (qss300 thing) has a cd dvd drive ?
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive Hope this helps.
Jan 28, 2013 | Computers & Internet
How do I reformat my harddrive using widows xp
You have to format a hard drive with a third party disk unless its a usb data drive
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
Hope it helps you
Apr 11, 2012 | Microsoft Windows XP Home for PC
XP Home Boot Problem
Restore Computer:
To start System Restore using the Command prompt, follow these steps:
  • Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  • Use the arrow keys to select the Safe mode with a Command prompt option.
  • If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  • Log on as an administrator or with an account that has administrator credentials.
  • At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  • Follow the instructions that appear on the screen to restore your computer to a functional state.
  • After restoring. restart your computer and use system utility tool like Reginout to fix coorupt windows files.
Dec 27, 2011 | Computers & Internet
Computer would not booy up. now it does but the password does not work
which operating system ant what type of computer??
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
also
how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased
or if using XP
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
hope this helps you
Sep 10, 2011 | Computers & Internet
When open the compeuter must press f2 for work my computer
if this fails to fix the problem you might try safe mode
is this the only key you have to press might be a log in requirement you have enabled
depending on your operating system click start control panel user accounts change the way you log on you should see log on options change the way users log on/off
learn more about user accounts increase log on security
hope this helps
Aug 24, 2011 | ASUS P5RD1-VM Motherboard
Restarts automatically
If you shut down your Windows XP-based computer, your computer may restart instead of shutting down. The computer may also restart unexpectedly while you are using the computer to perform certain tasks. An error message may appear on a blue screen when the computer restarts.
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advancedtab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If theAutomatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
To configure the way that Windows responds when the computer stops unexpectedly, follow these steps.
Note: You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
  1. Log on to the host computer as either an administrator or the owner.
  2. Click Start, and then click Control Panel.
  3. Under Pick a category, click Performance and Maintenance.
  4. Under the or pick a Control Panel icon section, click System.
  5. Click the Advanced tab, and then click Settings under Startup and Recovery.
  6. Click to select any one of the following check boxes under System Failure:
    • Write an event to the system log
    • Send an administrative alert
    • Automatically restart
I hope this has answered all your questions. If you have any other questions, please contact us at [email protected]
Mar 16, 2011 | Microsoft Windows XP Professional
Sir i have micromax q5 mobile when i install the pc suit then installdrv64.exe error found i. now the time i have use windows xp sp2..... plz give me how to use micromax q5 pc suite
The installdrv64.exe error indicates that the computer is installed with 32 bit Windows XP SP2 Operating System. Please unplug the Cellphone and re-install the PC Suite but do not install "installdrv64.exe" file as it is for 64 bit Windows XP Operating System. Now restart the computer and try connecting the Cellphone it should work now.
Mar 02, 2011 | Computers & Internet
I can't shut down my PC,It restarts again!
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Start up and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts. For additional information, click the following article number to view the article in the Microsoft Knowledge Base: 308427 (http://support.microsoft.com/kb/308427/ ) HOW TO: View and manage event logs in Event Viewer in Windows XP To configure the way that Windows responds when the computer stops unexpectedly, follow these steps.
    At last if nothing works then clear the "Star up"
  7. C:\Documents and Settings\All Users\Start Menu\Programs\Start up
    If you are not satisfied then If you are using XP then repair it.
thanks
Jul 05, 2010 | Computers & Internet
Hi I have Android phone G1-Dream. My phone restart automatic. So I am not getting the problem with the phone .If you know the solution please send me solution.
You may need to wipe the factory setting. To do so, Turn Off the cellphone, now keep on holding the Home button and turn on the cellphone. It go to the recovery console, now select WIPE or press the short keys mentioned over there and restart cellphone.
Note: You will not loose any data but you may need to resign to google and also may need to install some application.
Thanks and regards,
Anil.B.R
Nov 05, 2009 | Google Android
Nokia 6630 Handheld Logo
22 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
Ekse
Marvin
Marvin
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
