I Would suggest you have the printer self configure ( eg have the printer boot up when connected to the network with bootp/auto ip selected as my net connection , this will automatically input the available server addresses , when this has completed then i would manually re configure to better suit My needs as to what address is used for communication.
alternatively you can using the CMD function and Ping/ ipconfig commands in dos window to find the Ip credentials of the server for manual input into printer
SOURCE: My hp laserjet 4100mfp didnot scan and email the
It sounds like you need to reinstall the driver and application software and ensure that the unit is configured to scan and send. These are options when you do the initial installtion. This should give you application icons on the PC.
SOURCE: Hi Sir, i have setup my
Try using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English). If you need more help come back.Post /
thumbs / testimonial are
welcome!
Type the machine ip adress on the adress bar of the machine and hit enter.
Then the machine webpage will appear
1. Click the Network Settings link, login asadmin, username is admin and password is also admin and click the Services Settings link.
2. Use the SMTP server IP addresses in the Primary andSecondary Server fields rather than the server names.
3. Verify if the mail server is using the default SMTP portof 25. If it is not, then change the Port Number to match the server. Port 587is a commonly used port if authentication is required.
4. The Reply Email Address must be a valid local emailaddress for some mail servers or messages will be discarded. If using a Reply Email Address like: [email protected] [email protected] confirm that the email address actually exists.
5. If the server is running SSL (GMail uses SSL) for bettersecurity, check the box next to Enable SSL. Click here for instructions on how to setup scan to GMail.
6. Leave the User Name and Password blank temporarily andperform the Connection Test. A successful response will verify that the serveris really a valid SMTP mail server.
The following should be performed byan I.T. person
Mail server settings
1.Createa new user account and password for the mfp on the mail server this useraccount name , the name set in the mfp
