Question about Toshiba TLP S30 Multimedia Projector
Thoshiba projector installaton
DEAR SIR,
I  INSTALLED A THOSHIBA PROJECTOR IN CEILING.ITS WORKING NICELYBUT IMAGE IS COMING ON SCREEN TRANS VERSE(EXAMPLE HEAD  DOWN LEG TOP)PLS GIVE ADVICE HOW TO SOLVE,MY email id is [email protected]
thanks
jaleel
Posted by jaleel on
Marnus Jacobs
  • 563 Answers
Hi Jaleel
You should go into the Projector's Menu and flip the image if you turned the unit upside down.
Posted on Mar 26, 2008
How do you rotate the picture
If u have installed the projector to the ceiling, u will see the image upside down. for this u need to orient the projector image upside down
use the remote,
go to menu, installation, front ceiling option, u are done!
Dec 07, 2012 | Panasonic PT-AE8000U Full HD 3D Home...
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
Upside down picture how do you invert the images projected
Go to menu and select images and click arrow left or right to invert image position.
Mar 21, 2010 | Eiki LC-XB20 Projector Multimedia...
Casting image lower on wall
I don't know the model number for your projector, but most projectors are designed to place the image level with the bottom of the projector, which works great for tabletop mounting but not so great for ceiling mounts.
If you're mounted at ceiling height, try turning the projector upside down to see if it places the image in the right place on your screen. If that fixes it, then use the on-screen menus for your projector to flip the image and you should be all set.
Dec 09, 2009 | Dell Office Equipment & Supplies
Data Projector projecting upside down
If you go onto your menu and click on "setup". Press orientation and select the right one for your projector. It allows you to choose whether your projector is on a table top or ceiling mounted etc.
Feb 10, 2009 | NEC VT47 Multimedia Projector
Image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Sanyo Multimedia Projector PLC-XT25L
Click here to download the user's manual. Go to page # 50 if you are seeing the image on the right side of the screen.
Jul 18, 2008 | Sanyo PLC-XT25L LCD Projector
Nec projector
go into menu, under image, and chose ceiling.
Apr 08, 2008 | NEC VT37 Multimedia Projector
I NEED SOLUTION
Hi, Pls check the small Fuse for the supply of the fan. Or you can send it to us to repair.
May 26, 2007 | Toshiba TLP T50MU Multimedia Projector
Toshiba TLP S30 Multimedia Projector Logo
206 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
