SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
I want to delete what I have on there to make room for other stuff
Fred Block
  • 289 Answers
If you want to completely wipe it clean, format it. Otherwise, open the drive in My Computer and delete specific files as you wish.
Posted on Nov 26, 2014
1helpful
When I try to download a game app it comes up.as not enough room and to delete items I don't know how to do this or why it's s doing it.
its sound like you dont have enough space left so you need to delete some stuff to get more space..
so if you have other games on there that you dont play anymore get rid of them or what ever you dont use anymore get rid off.
Dec 05, 2016 • Cell Phones
How do I delete programs "MS Office" to make room for more useful programs?
Hi Art - I'll assume you're using a Windows-based PC so you have to go to Control Panel / Programs and Features. Once it populates with the programs that have been installed on your system, simply locate the desired program(s), right-click with your mouse and select Uninstall.
Good luck in this -
Matt
2answers
1helpful
4Gb to 3.2mb on my 4 GB Sandisc Micro card
format the memory card to do this from a windows based PC open "My Computer" connect the device to the PC and wait for the "removable media" to show up right click on the removable media and click format
Hard drive space needed
Simply buying the external hard drive is one thing. Did you simply plug it in, copy stuff over, or _move_ stuff over? You have to move stuff over in one spot to make room elsewhere. Cut-and-paste is your friend. Do not move programs this way -- just data, like videos, music, photos and word processing documents.
There's a wonderful program called ATF-Cleaner from http://www.atribune.org that can also search your computer for unused files. (Windows has a built-in program, too: click Start: Accessories: System Tools: Disk Cleanup). But the ATF-Cleaner is a bit more thorough, does more stuff. You may be simply wasting a surprising amount of hard drive space on stuff like temporary files that became pretty much permanent. You can also free up some space by deleting old System Restore files and the clike -- look through Disk Cleanup.
I keep getting a message saying not enough storage space. delete things to make room. but i have an sd card and i was wondering if i could move the majority of my stuff onto the sd card so i have more room...
your phone's memory is congested
try to remove unnecessary files one by one, dont try to delete them all immediately as itll cause your unit to run slow
you can also check if your unit has a master reset
bring it back the way it was before =]
98fe pc full memory
welcome to fixya
your back up files you wish to delete ?
well easiest way would be do a disk clean an on the list check everything and it should clear out all log and windows stuff your not using ....if not you can goto other drive in my computer and remove the stuff there manualy witch your more then liklely going to have to do .....might want to eaither remove it or get another hd ... maybe a bigger hd
hope this helps you out have a great day :)
Deleting music and putting new music on
try your media player, when you connect it to your computer via usb cord, a window should pop up and ask what you want to do, open with media player, or manually open media player, and press f5, and see if it recognizes the mp3 player, and if so, your set
Open Questions:
See all SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Questions
Top SanDisk Electronics - Others Experts
Marvin
Marvin
Mehandi Husain ...
Rob Hill
Rob Hill
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
