CIPHERLAB 8000 Series Handheld Mobile Computer Logo
Question about CIPHERLAB 8000 Series Handheld Mobile Computer
How do I get the craddle to turn on
When plugging in the cradle with the usb into the back of the computer is it supposed to turn on? How do we get it to turn on?
Dag Sandgren
  • 4 Answers
It depend of model of your cradle:
If cradle is without charge capability (suits CPT-8000), it get power from USB for internal logic and irda.
Cradles with charging capability ( two charging pin in cradle socket) need a powersupply to power both the charging of CTP-8001 and the internal logic/irda.
The driver need to be installed before connect the cradle to computers USB-port.
Posted on Jul 02, 2015
I reinstalled the driver of my garmin forerunner 205 but it is still not recognized by my computer. it has been working for over a year but now I do not get any connection and the device is not recognized...
When you connect the unit to the cradle is there any reaction from the unit? I would try using a different USB port and cord first if this dosent fix your problem the next step would be to obtain a new cradle for your unit. They can be purchased here http://www.gpscity.ca/garmin-forerunner-205-305-charging-cradle.html.
Hope this helps!
Drive is not ready to be read ?Error Check/device/harddisk1/DR7 ?
if you external hdd do not show on other computers, usually it meant that power supply on these casings die... but in this particular case it is possible that power supplied by usb port is insufficient to support data transfer. connect recommended power supply (on the back of this particular model you have usb plug and power plug, power supply is/was sold separately) usually hdd inside is still fine and retain data.
if this did not solve your problem, i would suggest purchase little powered universal hdd craddle, they cost about $15 to $25, remove, hdd from casing and connect to the craddle. data should be then accessible directly from your usb port.
as long as hdd is turning, data is accessible and recoverable, even if disk was wiped off.
2answers
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
16helpful
Garmin 305 wont power on, wont charge on cradle
Same thing happened to mine. Put the unit in the cradle (just like you are going to recharge it) and press the reset and mode button at the same time for 3 seconds. This will "wake" the unit up.
We have a baby snoopy bassinete and need a new ******** for it
I was given a baby snoopy basenette and its in good condition however the craddle part slides side to side if you move it, is it supposed to be that way, also i took the covers off to wash them and i cant figure out how to put the canopy back on theirs two bars, a thin one and a thick one, which one goes in the front where the ruffles are?
2answers
IPAQ H5555 connection problems
Hi, This could be due to a few issues, try these soloutions in order below: 1) If you have a jacket connected to the ipaq it could be preventing the ipaq from locating correctly on the connector. Remove jacket and try insering again. 2) Check that active sync is set up to detect the device on the usb port. The cradle for the ipaq may have a serial and usb connector. Ensure that just the usb connector is attached to your laptop. Try connecting again. 3) You may need to uninstall the USB cradle if it was connected before installing active sync. Try the following steps if this was the case: a) unplug the USB cradle b) uninstall active sync c)Click start then click control pannel then click system. Then click on the hardware tab. Look for the device under USB, right click on the device and then select uninstall. d) restart the laptop e) Install active sync f) ONLY after active sync has installed you can now plug the cradle back into the usb socket. g) Now connect the ipaq, it should now detect it.
3answers
Why does my axim power on by itself?
I've noticed that mine will power itself on as well. But is usually goes like this... 1. Sync with computer 2. Unplug cable 3. Turn off Axim 4. ~1min later...Axim is on and at the password screen
PC restarts when VISOR put on USB cradle fro hot sychn operation
USB glitch is most likely, depending on which operating system you are using. This is especially common with USB hubs. If using a hub, try plugging the cradle directly to the computer. If still having a problem, unplug all USB then use Hardware Manager (in the Control Panel) to delete all USB entries. Restart the computer and plug one USB back in at a time. If this does not help, try the forums at www.brighthand.com.
My E-125 isn't working properly...
If your craddle has DC power input that charges the PDA while in craddle, try setting the power configuration so that when the PDA is on external power, there is no blank screen timeout, and no automatic shutdown (it's in the Settings menu). This way, it won't power down while in craddle, and you won't get this problem you're having.
Top CIPHERLAB Computers & Internet Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Larry Ng
Larry Ng
Are you a CIPHERLAB Computer and Internet Expert? Answer questions, earn points and help others
