Starting about a year and a half ago, the convergence stopped auto aligning but would fix itself after the unit warmed up.
Now, the convergence isn't working much less sporadically and it seems to finally have failed for good.
I've read many other posts that indicate this is solved by replacing or resoldering the convergence IC.
Any advice on where to get replacement convergence ICs and how to install and repair.
Considering calling a local repair shop or getting my brother who's an electronics wiz over to my house to make the repair.
Thanks in advance!
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
You can see some more examples and find a fix hAuto convergence no longer works on Mistubishi WS- - bb0cf99.pngmg src="/uploads/images/bb0cf99.png" alt="bb0cf99.png" class="h_mi" />http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
