JustAnswerhttps://www.justanswer.com > TV Problems
Sep 27, 2012 - Unfortunately, the symptoms you are experiencing (flashing power/status light, tv won't power on) are generally symptomatic of an internal ... 1 answer · Top answer: p0llinate : Hello, and welcome to justanswer, a pay site for expert technical help. My ...
https://www.askmefast.com > My_nordmende_tv_mo...
Normende tv red light wont come on Nordmende tv blue light flashing Nordmende ... said: nope. will turn on and work fine until the screen dims, goes black.
Hiteker appear to make cheap and nasty televisions. What you have doesn't sound like a television, or a computer (the Category) you posted to. This is why we ask for 'make model (what it is)' in all questions please.
The simple guessing answer for your mystery item is that you connect it to a computer and back it up.
Find helpful customer reviews and review ratings for Hiteker TL50Z10AH-TP 50-Inch 1080p 60Hz LCD TV (Black) at Amazon.com. Read honest and unbiased product ...
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
I just changed out the invertor boards and mine was fixed. I had the same problem. Im not a TV repair man but replace the board thats buzzing and it will work again.
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
I am from Australia and this TV is a dud. We purchased it 12 months ago and it has been to repair twice. It is doing the same as the above message. Prior to this the screen would half, horizontally, go black or white with coloured vertical lines. Never buy another of these.
