Question about Kenmore HE5
My kenmore he5t washer will not turn on. The on
My kenmore he5t washer will not turn on. The on button beeps, but does not turn on.
Posted by tomsik on
Anonymous
I have the same problem . If I power cycle mine enough times I eventually get a F70 or F71 code. My research online suggests that the user interface board has a problem and needs to be replaced.
The good news is the warranty covers these boards for two years. The bad news is they are $360 if you are out of warranty.
HTH
Posted on Jul 02, 2009
Washer wont start
possibly door switch, check first! if not main board replacement, is it under warranty?
Feb 18, 2015 | Kenmore Elite HE5t Washer
Kenmore he5t washer Changed the pressure switch.
F21 means long drain. Yes, there is something be in the hose. You need to open the filter and clean the pump, too.
Oct 19, 2013 | Kenmore Elite HE5t Washer
I have a Kenmore smart wash quiet pack 9 HE5t and when I try to turn it on it make a noise but won't turn on
Please check the motor belt , the drain pump and the inlet valve. If the noise seems to come from any of these it is possible that it trips off the circuit due to a fault and so must be confirmed.
You can remove the connection to the seperate items to confirm if the panel switches on.
Jul 02, 2012 | Kenmore Elite HE5t Washer
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Nov 07, 2010 | Kenmore Elite HE5t Washer
F20 message on washer kenmore elite HE5t
http://www.fixya.com/support/r3608632-f20_error_code
Feb 28, 2010 | Kenmore Elite HE5t Washer
My HE5t front loader not powering on
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 10, 2009 | Kenmore Washing Machines
New HE5t steam dryer will not turn on
What was wrong with your dryer? I am having that same problem?
Dec 27, 2008 | Kenmore Dryers
Kenmore Elite HE5t Power and Errors
try hitting pause/cancel twice to clear the codes
May 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE5 Logo
551 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
