SOURCE: Cant log in
For these problem you encounter i will want you to work gently and tenderness on your laptop .Now take this protocols firstly, you will try and know that you will loose some data on your pc because you will reformat the system with a winXP bootable CD and then you will reformat it and reinstall the Packages and drivers back or secondly, you may not format it but click on your "R" button on the window XPCD setup and it will repair the system and it will be okay then the space for you to enter your username and login to your network or to your system i wish it will be okay anything that happen after then do tex us.
SOURCE: My Laptop screen's color broke up
I don't know of a real solution for this problem, but i know hitting ALT + TAB to go in and out of the games helps restore the resolution.
SOURCE: After Chrome uninstall Web page icons gone
I fully agree and sympathize with you.
I faced a similar problem and here is the solution for it.
First uninstall Google Chrome (From what you have written; you have already uninstalled it).
Go to "Set Default Programs" (Control Panel>Default Programs>Set Default Programs)
Select Internet Explorer and click Set this program as default
Select Microsoft Office Outlook and click Set this program as default
Run Registry Editor (regedit.exe) and browse to location: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Ext and change the value data of all DWORD entries from 1 to 0.
Launch Internet Explorer first; launch your Mail client (hopefully Microsoft Officer Outlook).
Check if all is well and you are now able to open links from within your Mail client.
If all is well now, you may change your Default Program settings to Firefox.
P.S. Just remember to say thanks :) and you can always change the Firefox icons, you do know how?
SOURCE: i want to get rid
Close the Google Chrome, now follow the steps:
Click "Start" > "Control Panel" > "Add/Remove Programs" and locate "Google Chrome" from the lists of installed programs, once it's located, highlight it with your mouse (click once) and click "Remove" on the right-hand side, and follow the onscreen instructions.
If you need further help, let me know with more details.
Good luck.
Thanks for using FixYa.
SOURCE: How do I change the Language on Google Chrome from
1.Open Google Chrome.
2.Open the settings menu from the wrench icon, then click "Options."
3.Click "Under the hood," then click "Languages and spell-checker settings..."
4.Click "Add," select "English," then click "OK."
5.Click "Display Google Chrome in this language" then restart Chrome to apply the settings.
Hi austin taite, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
What version of windows are you running?
