Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have replaced bulb and it does not work - Mitsubishi WD-52525 52" Rear Projection HDTV
Posted by wand martin on
Goodman Custom Design and Installation
  • 139 Answers
What does the TV do when you try to turn it on?
Did you put the lamp door back on before you tried to turn the set on?
Posted on Apr 18, 2014
Amana fridge replacment bulbs not working
You pretty much answered your own question. If the remaining working bulb works in the socket and if the base seems to be not long enough on the replacement bulbs - there is most likely a problem (or by design) - with the bulbs. The best way to be sure is to ensure the correct bulb type - c6, c9 etc.
http://www.appliancepartspros.com/whirlpool-light-bulb-8009-ap3607217.html 40 Watt Appliance Bulb
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 01, 2017 | Amana ABB1927DE Bottom Freezer...
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
1997neon shifter won'T LIGHTUP
see this step and fix it. God bless you
Diagnosis: The problem could be a bad headlight bulb, a loose bulb or corroded bulb socket, a bad ignitor, or a bad ground connection or wiring harness fault at the ignitor. High Intensity Discharge Xenon headlight bulbs do not have a filament, so if the bulb has failed it may be cracked or leaking. The bulb also requires a high voltage ignitor to turn it on and keep it glowing. On some applications, the bulb and ignitor are one unit and can only be replaced as an assembly. On others, the bulb and ignitor are separate components, and can be replaced separately. The bulbs are expensive to replace ($50 to $100), and the ignitors are even more expensive to replace (up to $200!), so you want to make sure you have correctly diagnosed the faulty part BEFORE you replace anything.
TIP: Swap the "good" bulb that is working on the other side to the headlamp that is not working. If the headlight now works, you know the bulb you removed was bad and needs to be replaced. If the headlight still does not work, try swapping the "good" ignitor module on the other side to the side that is not working. If the headlight now works, the problem was a bad ignitor, not the bulb. You need to replace only the ignitor and not the bulb. If the headlight still does not work, you have a wiring fault such as a loose ground connection, a bad wiring harness at the headlamp housing, or a corroded bulb socket.
Oct 16, 2012 | 1997 Dodge Neon
Pentair PG 2000 light stopped working. Replaced metal halide bulb, worked for a few hours then stopped working and wouldnt come back on. Replaced capacitor, but light still doesn't work. Have verified...
Have you replaced the ballast or did you just replace the capacitor? If you did not replace the ballast I would start there. Also if you have a multimeter check your bulb for continuity you may have gotten a bad bulb.
Jun 11, 2011 | Home
Head light high beam on right side does not work
Dear Sir,
If only rh headlight high beam is not working then it is problem with bulb or coupler at bulb end, if u have spare bulb replace it and check it if it work then bulb was faulty if not then problem with bulb socket , if you don't have spare bulb you can check with rh side bulb for testing purpose only, i hope problem will solve after replacing bulb,please let me know if any issue. Thanks.
Oct 09, 2010 | 1994 Mazda 323
Passenger front blinker stopped working - pulled assembly out to replace bulb and it started working
check bulb somethime the bulb bruns out and then it makes a connection and starts working,or the socket is bad,take a good look at bulb or just replace the bulb if it acts up again then replace the socket. hope this helps.
Dec 28, 2009 | 1998 Honda Accord
CFL bulbs won't work in ceiling fan?
they should all work. The only problem might be if they are connected via dimmer. Dimmers and CFL does not work together.
Mar 08, 2009 | IBM ThinkPad R50e Notebook
Can't find replacement light bulb:refrigerator model ET18DKXWW00.
Your problem may be in the bulb receptacle or the light switch.
If you have a voltmeter, let me know and I will tell you how to check it.
Mar 04, 2009 | Whirlpool Refrigerators
Lt frnt turn signal bulb and lt headlamp not working, replaced tu
probably need headlight bulb too, check fuses first.
Jan 10, 2009 | 2002 Volkswagen Jetta TDI
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
