Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have bulb im mitsubishi tv and it is struck and cannot be remove
Posted by wand martin on
Goodman Custom Design and Installation
  • 139 Answers
The lamp housing has some screws you need to loosen, did you do that?
Posted on Apr 18, 2014
How to fix a 73 in mitsubishi tv that was struck by lightning?
You will need to take this to a repair center. Expect it to be un-repairable.
Aug 03, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
Got cd struck in factor 6 dis changer 00 mitsubishi diamante
If the disk is stuck in the changer then the changer has a defective part and will need to be removed and sent out for repair, Send a note with it that you want your CD back with the repaired changer.
Sep 12, 2012 | Cars & Trucks
Tv is getting dimmer
Brenda, Your projection bulb is about to die. Go on eBay, so a search for the bulb. Only buy a genuine Mitsubishi bulb to replace it. Or order one of these;http://www.shopjimmy.com/mitsubishi-wd-65c9 Get one of the "assemblies".
Removing and replacing the bulb unit is SUPER easy. Unplug the TV!! You unscrew the one screw on the litle door and the lower right, back side of the TV, then unscrew those two screws that hold in the unit, and slide it out. Slide in the replacement, and tighten everything up. Put the door back on, and plug it in.
Nov 25, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
I have a 65" Mitsubishi
Im, not sure what it is that you are wanting to know about this Model# WS65411,But this TV has 3 Tubes Red,Green,Blue their is No Bulbs Just 3 Picture Tubes.
Encompass Parts Distribution List Parts and PN# for this Model 1-800-638-3328
Visit this website for Part Numbers for R/G/B Tubes.
Apr 12, 2011 | Mitsubishi WS-65411 65" Rear Projection...
Im trying to replace the bulb on my friends tv tonight, we removed the access panel and removed the old bulb but there seems to be another lens that shines into the bulb that emits from the side and we are...
What are you talking about? Just replace the lamp, if that does not solve the problem, also replace the thermal sensor. Nothing else. If you've damaged anything, take it to a repair shop. We are Mitsubishi authorized.
Jan 18, 2011 | Mitsubishi WD-Y65 65" HDTV
How to replace a bulb in a Mitsubishi WDY65
If your TV uses a bulb - there will be a access panel on the rear of the TV. Remove the panel to pull out the lamp cage.
Feb 20, 2010 | Mitsubishi WD-Y65 65" HDTV
Where does new bulb for picture go inside the TV?
The bulb is in the front of the TV. Remove the front lower cover by pulling oneside at a time. There will be a lable next to the cover for the light housing.
Feb 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
915P043010 have the bulb
Pull the panel off where the speakers are the entire plastic lover comes off. Next, make sure the tv is unplugged and has been off for at least 15 min, preferably longer. See the box with 4 screws take those out... it should have a set of instructions or some sign saying it contains the bulb. Anyway.. after that door comes off, peer inside and you'll see the bulb about 6-8" back and has set screws which must be unscrewed completely before it can come out. Be careful, don't yank the bulb out. Then place the new bulb in, reverse the process I told you, plug the tv in and reset the bulb when it askes if you changed the bulb.
It is really easy on mitsubishi tv's to change them... post back if I can be of further assistance.
bob
Mar 10, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Red light came on tv , replaced lamp and still no picture
Look at it really carefully where the bulb plugs into the lame the connector is not sitting firmly on it reconnect it and make sure it's firmly connected to the plug.
Dec 10, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
