Most volume controls have a retention nut on the front of them. If you take the knob off, you should be able to see and remove the nut.
Can you use a sheet metal screw to extract the pin from the broken connector?
I have thought of it as a solution, but I was afraid that it might damage the shell. Do you think it isn't a very big risk? I have almost reached it from the other side now, but am afraid to damage the system board because it isn't easy to pull it off, do you have any idea how this is fastened?
Use the screw! It is easier and less likely to damage the main board
SOURCE: Hi, I have a SR92
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause? If it's only an analog source doing it I would suspect a bad audio cable or a switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
