Sony ST21i Xperia Tipo Black Logo
Michael Mike Nutbrown Posted on Mar 03, 2014
Phonebook not loading - Sony ST21i Xperia Tipo Black
Andras Arsziri
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Jun 20, 2014
Andras Arsziri
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
2290
Points
12
The range of possible root causes is huge, it is almost impossible to tell exactly what might be the problem. Before getting the device to Sony for check, i would simply try to reinstall the Operation system on the phone with the help of a pc software called Sony Update Service. This is my only guess or advise.
1helpful
Does my bluetooth phoneobok have to (re)transfer everytime I start my car? Can I simply refresh it periodically, when I update my phonebook?
Don't know your car; but with mine, it does not save the whole database when off. My wife and I have different lists and I guess it would recognize other family members too.
What's the problem with having a fresh load each time you get into the car?
I can't get apps on my cruz reader
http://www.supertooth.net/EN/HD/#page=page-5
With my HTC phone, when I say the key sentence to call one of my favourite contacts (for example, call first contact), my SuperTooth HD says "not in phonebook":
  • With my HTC phone, when I say the key sentence to call one of my favourite contacts (for example, call first contact), my SuperTooth HD says "not in phonebook": You must create your favourite contacts in the phonebook of the SIM card, not in the phonebook of your HTC phone. Once you have created your favourite contacts in the phonebook of the SIM card, please refresh the phonebook of your SuperTooth HD or do the pairing again as indicated below.
1helpful
How to export phonebook to pc? How to export
Re: Export phonebook to PC:
hi, you can transfer your contact details through your pc, by first u may use phone usb, then connect your phone usb to computer and go to my computer, chech for removable disk and find their your phone motorola RAZR V3, open it, go to phonebook and you may copy your phone contacts by simply clicking right click,choose copy and you may save it to your documents.
RE: Transferring phonebook to another mobile phone?
you can do that by first activating your bluetooth under connectivity. once activated/on go ack to phonebook, click send via bluetooth.
2helpful
3helpful
2answers
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Can't enter phonebook numbers - Says memory full
Clear out your caller ID, These phones use a shared memory, once the caller ID is cleared, you should be able to store names/numbers in the phonebook.
Ming A1200 Phonebook Problem - Fail to load/delete
Hi ;
I have the exactly problem :(
please help me
I cant find out the solution
even I try to copy my contacts to PC but the Motorola software cant read contacts from my phone :(
Blue tooth phonebook
The unit does not save the phone book, it loads it each time your bluetooth phone is in contact with it. To verify this, turn off the bluetooth phone, then try to access the phone book in the GPS unit. It should not come up.
LG K800 chocolate
you have to take the photo in 72x72 size in order for it to be saved in the phonebook
Phonebook problem
is your phonebook located at the sim or in the phone book?
Top Sony Cell Phones Experts
Aron
ADMIN Eric
ADMIN Eric
NOEL
NOEL
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
