I bought a Logik car radio but every time I switch my car on I have to set the station and the time all over gain.. I dont even bother to set the time because it changes back to Midnight every time I
LOGIK USB/SD CAR RADIO U23L is the car radio I have, When I swtich my ignition on and set my radio station and time then everything isin order then when I switch the ignition on again every thing restarts from scratch and I have to do it all over again. I need advise on how to keep my setting all the time cos I keep searching for my radio station everytime I switch my ignition on.. be it 2 minutes or two hours when the ignition is off I lose all the setting.. and that is titring.LOGIK USB/SD CAR RADIO U23L is the car radio I have, When I swtich my ignition on and set my radio station and time then everything isin order then when I switch the ignition on again every thing restarts from scratch and I have to do it all over again. I need advise on how to keep my setting all the time cos I keep searching for my radio station everytime I switch my ignition on.. be it 2 minutes or two hours when the ignition is off I lose all the setting.. and that is titring.
You can't post conmments that contain an email address.
Re: I bought a Logik car radio but every time I switch my...
You forgot to hook up wire to fuse box with all time connection to power even when car is off.if u connected thw stereo red wire positive black ground theres always another wire yellow/blue/orange that needs to be connected to constant power that wire once connected will have all ur memories stations set and clock.ned to check wiring
Make and model of the car?It's rather simple.Many German and French cars have the permanent and the accessories power cables switched.Switch them back from the stereo's connector's cables.(The red to yellow and the yellow to red).First it would be a good idea to check that out with a voltmeter.
unless you are right next to a station that has some power, set RF gain to max. Mic gain can be set at max level to 3/4 with no problems. If you have an amplified mic, then mic gain should be set at about the 12:00 position. hope this helps
the knob that turns the radio on and off is the volume potentiaometer.turn it 1/2 wayopen.the next knob is the squelch maqke sure it is all the to the left.the next knob is the mic gain and the RF gain.Set the mic gain at 1/2 and the RF gain all the to the right.the next knob is the delta tune,set it 1/2 way the next knob is the calibration knob leave it alone.Now above those knobs are little switches .the third switch from the left is for CB/PA make sure its on CB. check the WX switch and make sure it not on a weather station. and finally the last switch to the right is called a dynamic squelch switch.Make sure it is down. with all said your radio should be on and you should be able to hear sound. If not ,take an external speaker and hook it to the external speaker plug in the back of the radio.If you hear something then you internal speaker is junk.replace it .
Is it incorrectly wired? There should be one wire going to a permanent 12V feed, so thsat even when the car is off it has power. I sounds like it doesn't have that connected.
cuts out ? well, all FM radios cut out for.: 1: weak station. 2: stereo can not be held in properly( can be bypassed on most RAD , pick mono) 3: AGC drop out, same as #1
on better radios (RTM) you can defeat these default features. set the FM to mono channel mode, and now you hear all stations. also kill the AGC mode. this allows you to hear the station. and static or both. like a Marconi radio of days of old. modern radios are programmed to blank weak stations. tis a fact. im a tech and tuned these features, for 50 years.
ok the fix, 1: move closer to station 2: get a better antenna (vast choices) 3: go to station and turn the gain knob up and get arrested by FCC.
I recommend that you will post your question under
the correct category (personal radios). You can also contact the store that you got it from to get the instructions.
Hi. Try this: change your language settings to a European language. After that you can choose your radio type: choose Europe. Exit the menu.
Now you will be able to choose radio stations with two decimals, for example fm 88.15.
I hope this solves your problem.
When you find a frequency that you want to store in memory, press one of pre- set tuning buttons 1through 6 and hold until the preset number stops flashing. The number you have pressed will flash in the preset number indicator and then remain lit. The selected radio station frequency has been stored in memory. The next time you press the same preset tun- ing button the radio station frequency is re- called from memory.
Look here, it should help: http://support.thetechguys.com/layout.aspx?CatID={6e93bd13-7e35-4d6c-b6d0-9ef772b186f4}&ID={f847278f-41cf-4a00-9874-93770b7a1905}
Before you call a doctor or an exorcist, verify that you're using your shortwave receiver under normal condition. There are several factors which affects reception of whortwave programs and signals.
1. Check for the time and frequencies. Depending on your country and location, all Shortwave time zones are based on World Time in UTC or GMT ("Universal Time Coordinates" or Greenwich Mean Time") In my country (Philippines, Asia) for example, we are 8 hours advanced from World Time. You can check your time zones and regions using a world map.
2. Check for propagation and band conditions/ openings. During daytime higher frequencies such as 9 -21 Mhz are active, while nightime frequencies are the lower bands such as 3 - 9 Mhz. Daytime and nigthime divider frequency is about 10 Mhz, that means you might receive signals under most conditions during daytime and night time. Check some technical books on amateur radio operations or magazines for radio reception. It might be worthwile to study books or materials on receiving international broadcasts stations before you can receive good or adequate shortwave signals. This might become your hobby too, "DXing" or receiving distant stations from across the world. Try it, but it might be an addicting hobby once you're drawn to it!
3. Check if any shortwave station broadcast in any specific time of day at any frequency. Shortwave broadcasts are scheduled based on band openings mentioned above. If for example I'm a Shortwave broadcaster from Asia, and would like to broadcast my signal through the Americas, I would use band openings with respect with time zones. If it is night time in the Philippines, and daytime in the Canada, I would use the higher frequencies to propagate my signal. So I would specify the time for example "8:00 pm Philippine local time, 12 hours UTC, and 7 am in Canada"--- Asia: 8 hours advanced to UTC, Canada--- 5 hours behind to UTC). So shortwave broadcast schedules varies. Broadcast schedules are available on the net, just search for the Shortwave station you want to hear such as Radio, Japan, Radio Australia, BBC, DW (Deutche Welle) Radio in Germany, China Radio International... There's too many shortwave stations waiting to be discovered out there! Check some books and magazines too such as Popular Communications, Monitoring Times, Passport to World Band Radios, World Radio and TV Handbook, etc. You may want to check if any station would be broadcasting in your dialects as most of these mainstream and regular broadcasters are multilingual.
2. Check your location. If you are using your radio indoors, shortwave signals might not entering your homes or offices due concrete walls and metal railings or fence. There are many factors which blocks radio waves especially in the HF or lowetr bands. Try receiving AM (Mediumwave) first. If it cannot receive any AM station, then you would not receive any Shortwave signal at all, even if you extend fully the telescopic whip. If you cannot receive AM or Shortwave signal indoors, try using your receiver outdoors.
2. Check for local interference. Your receiver might be receiving interference from noise generating gadgets such as PC monitors, TV sets, faulty wall adapters or switching power supplies, motor operated appliances such as washing machines or vacuum cleaners, flourescent lamps, etc. Try turning off or unplugging each of these mentioned gadgets to see if they are the cause. Faulty house wiring or powerline noise might also cause some interference noise which could drown shortwave signals, verify this with your local electrical technicians.
3. Check your radio's settings. Depending on the radio that you use, there might be settings such as attenuator or RF gain, be sure that attenuator are set to zero or turned to off, and RF gain to high. Attenuator must be turned to minimum or OFF position, unless you are receiving too much signas from nearby radio stations. Setting attenuator to mid or high position will attenuate most weak signal, and only those strong local stations will pass through. Setting too much attenuation will prevent you from receiving any station at all. Same with RF Gain, always set it to highest gain setting unless you are receiving too much signals which might overloads your shortwave radio.
4. If these troubleshooting efforts above doesn't works and you still cannot receive any station, then your radio's front end parts might had burn out due to signal overloads. Burn parts might include one or several transistors or diodes. Let your local service technicians check your radio and solve the problem for you. If your radio is still under warranty, send it back to the store or dealer, and let a qualified technician do the repair.
MANNY DE GUZMAN JR.
SoundMagik Home Studio
Site Creator, Teen Models 2007
I've also signed up an account at Total Popstar, uploading some promotional videos. You can watch and rate my videos (you can find my videos on the right side of the screen), just click the link here: http://www.totalpopstar.com/?profile/index/&1740
Thank you very much. I hope I'll really be of help here at FIXYA.COM!!!
