SOURCE: Samsung Yepp YP-T9
Yeah I had exactly the same problem with the freezing on start screen.
What you need to do is a clean format of the unit.
Here's what to do:
1) Hold Menu and the A+B Button (the record button with the red circle)
2) With the device now off, connect it to your computer. You should be able to see it's profile under My Computers
3) Right click on the players icon and select full format.
4) Disconnect and restart your player. It should be working now.
The downside is that you will lose EVERYTHING on it but so far I think that's the only way of solving the issue.
This issue is most likely to be cause by a corrupt file that you have copied onto the player.
Cheers,
Robert
Cheer
SOURCE: Samsung yepp/ YP-T6 reformated now can't put tunes back on.
Use the Samsung Firmware Updater to fix it. Mine did what all of you are speaking about. I was ready to toss it then I tried the firmware updater on the CD and it fixed it. You must copy all the files from the \setup\Programs\ and \setup\Binary\ folders on the Samsung CD to a folder on your hard drive. Then connect the player via USB and run stupdaterapp.exe. It will search for the device and pop up a menu. Check the Format Data Are box and click start. It takes a few minutes and wipes the device clean but it fixed mine.
SOURCE: serial number for samsung yepp YP-T5 mp3 player
Look on the side of the player.You should see a silver decal near the bottom. The third line with apx 13 digits of letters and numbers is the serial number you need.
SOURCE: I need a user manual
You can download and print the user manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa
SOURCE: How do I get my songs to be sorted in alphabetical order in my Samsung Yepp YP-T7F?
How do I do it I need help
