It just started 2 days ago. We leave the computer on most of the time , but one day came home moved mouse to wake up screen as usual and after 2 seconds went black,. Made several attempts to turn on again and still went black after 2 seconds. Once in a while it will stay on except this last time has not. What should I do. Is it worth fixing, a quick fix myself or just go buy a new monitor?
Problems like these happen all the time with LCD monitors. Usually one of two things. Bad Capacitors or a bad backlight. To check this, take a flashlight and point at your monitor (usually at a high angle) and see if you can still see the desktop faintly. If so then its either the back light or capacitor. Backlights shouldnt need replaced too often as they have a extremely long lifespan. Capacitors are relatively cheap and easy to replace, all is required is a soldering iron and an inexpensive trip to a Radio Shack. Though this isnt your monitor, it is a very good tutorial on how to go about replacing the capacitors.http://www.wizardanswers.com/liquidvideorepair.html If it is the backlight, here is another tutorial for that :D http://www.inventgeek.com/Projects/shorts/lcdfix.aspx
