When I start my vacuum it sounds like an airplane. It's something with the brush, I think, but I can't figure out what. I changed the belt, but it got louder. If I can't quiet it down, it's gotta go. Still picks up and works just fine though.
SOURCE: Eureka 4870 vacuum brushroll control doesn't work
Use two hands to presscontroll button upward until it snaps in place.
SOURCE: belt change for eureka capture
Lie the vacuum down so it's completely flat, the back of it facing up. On the bottom of it, on the grey plastic, there are instructions. They say, to access the belt, remove the screws numbered 1, 2, 3 & 4. Then look at the four corners of the bottom of the vacuum and you'll see these numbers. You may need a flashlight to actually see the screws because a couple of them are pretty deep inside the plastic. Loosen them with a long shafted, Phillips screwdriver. Stand the vacuum back up and the screws should just fall out. Then you can easily pop off the cover to change the belt.
SOURCE: How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
SOURCE: In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
