My NEFF built-in dishwasher (model no. S44M55N1EU/70)is leaking from the bottom somewhere at the back side. This happens during certain period of cycle when the machine is draining. I don`t know how to pull out the machine and can I fix it by myself (as it is out of warranty). Thanks
SOURCE: Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
SOURCE: Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
SOURCE: DISHWASHER IS LEAKING A LOT OF WATER
I had the same problem with my machine - ie lots of water coming out front about two thirds of the way through the cycle - engineer (local and very reliable) knew as soon as he came in that I had started bying Powerball 5 dishwasher tablets - they produce too much foam (try opening the door during the cycle and see the amount of foam) and it therefore comes out of the overflow parts on the door. I tried Magnum 5 and got the same problem. Now I stick to either Asda's own basic (not the 5) or I buy the Magnum ones and cut them in half. Has never leaked since!
SOURCE: Neff Dishwasher won't drain
I've had this problem a couple of times with my dishwasher. In both cases, the cause was a shard of broken glass that had managed to get past the filters and jam itself underneath the impellor. Hard to see, but easy to fix. First ladle out the water.
Pull off the lower rotor arm, unscrew the filter and take out the filter bowl, tray and cylindrical filter. Get as much water as you can out of the filter cavity.
Then, using a Torx-20 driver, remove the screw holding the impellor cover and lift the cover off. (this is the small bit of plastic at the left end of the filter cavity.) Check whether the impellor can rotate freely by spinning it with your finger several times - if it jams or grinds, then there's probably something jammed under it. (It may seem to be fine at first, so do check thoroughly, as any debris can move around with the water flow and only jam occasionally) You may have to use a cocktail stick or similar to poke out anything that's stuck underneath.
Glass is a particular problem, since it's almost impossible to see when there's any water around (it's easy to cut yourself too!)
Anyway, that's worked twice for me now - and I didn't have to even move the machine out of its cupboard to fix it.
Hope that helps.
SOURCE: dishwasher not draining (neff slimline intergrated)
I had this problem and eventually after trying everything short of pulling the dishwasher out and checking the hoses I tried Finish Dishwasher Cleaner. Much to my surprise, IT WORKED.
