You didn't specify the model of your Concord camera, but most of them take SD cards. SD cards are getting a little hard to find, but you should still be able to find them at most department, electronics, and office-supply stores. Check the manual to see whether your camera also can take SDHC cards. SD cards are limited to 2GB or smaller, while SDHC cards go from 4GB to 32GB.
SOURCE: Memory Card Error
Sounds like the camera does not support SDHC. Check manual to see if this camera supports high capacity SD cards.
SOURCE: Missing pictures
Hey flowernthe,
The error message “card cannot be read" means there was and error when the camera tried to access the memory card. To fix this you should make sure you are using the right kind of memory card, which for this kind of camera is a SD card, and it does not support SDHc cards. Since this camera uses SD cards I would make sure the slider on the side of the card is not set to the locked position. If this doesn't help I would make sure the memory card connecters are clean, and if they're not you can use a rubber eraser to clean them up. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: Finding new memory cards 512mg for concord camera 3341z
Walmart, Kmart, Radio Shack, Best Buy, Pharmacies, grocery stores, etc. They are for sale almost everywhere.
