Question about Maytag MMV1153A Microwave Oven
Kenmore model 721.626 fan - Maytag MMV1153A Microwave Oven
I got a Kenmore microwave hood combination model number 721.80032 is it a hood fan to and how do i just turn on the hood fan
The model number 721.80032 is a partial model number; it indicates the build series. I found the Kenmore microwave, 721.80032700. The final 3 digits indicate the panel color and similar details.
Assuming the microwave was installed properly, it should work as a hood fan. Press the touch pad with the fan icon (underneath it says Hi/Low/Off) to get the desired fan speed. The icon is on the lower left of the control panel; it's below the Cook Time button and to the left of the Light button.
The manual for the 721.80032700 is available here: https://www.searspartsdirect.com/partsdirect/user-manuals/72180032700-kenmore-parts-manual?manualIndex=0 . The direct link to the Owner's Manual is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0710653.pdf . See pages 9 and 14 for using the exhaust fan.
I hope this helps.
Dec 25, 2017 | Kenmore Microwave Ovens
My fan will not shutoff unless I unplug it it is a microwave Kenmore . model 790.8033
Check to make sure all the door switch contacts are opening and closing properly, and in the correct sequence. Also check the relay that provides power to the fan.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Nov 16, 2016 | Kenmore Microwave Ovens
What does F44 error code on Kenmore Elite model 790.4890 mean?
You may be missing a digit in the model number. I believe that this microwave was built by Electrolux for the Kenmore line. The F44 error indicates that the external cooling fan for the microwave is spinning too fast. This can be caused by a blockage. Check if there is anything blocking the airflow. Make sure that the voltage coming into the microwave is correct. If your voltage is too high, then the fan will spin faster.
The fan is part 108 on this diagram: http://www.searspartsdirect.com/model-part/79048903000/0583/0125400/r1009032/00003.html . It's at the back of the deflector at the top of the microwave. This is the diagram for the 790.48903000 .
If there is nothing wrong with the fan (spinning normally), then the problem is between the fan speed sensor and the control board. This should be fixed by a professional.
I hope this helps.
Jul 15, 2016 | Kenmore Microwave Ovens
Kenmore microwave hood combination, The fan wont
With the full model number, chances are we could have helped you more.
If the cooktop lights recently failed, it may need circuit board repair.
Or it may be a failed hood TCO.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 15, 2013 | Microwave Ovens
Kenmore Elite Microwave oven 63792 doesn't heat - all lights, turntable, fan, etc. work just fine.
Most likely it would be a bad magnetron since the light, turntable, and vent fan are running.
Sep 10, 2013 | Kenmore Elite Microwave, Model...
Kenmore model 721 850 the cooling fan doesn't run all the time
This could be due to a intermittent micro switch, or a faulty cooling fan. This is critical in keeping the magnetron cool when cooking.
Apr 04, 2012 | Kenmore Microwave Ovens
Kenmore Microwave Oven model #401.80082700
Sounds like a bearing is tightening up when it get heated up with use. Then after a cool down period it works normally until using it heats it up again. Eric
Sep 15, 2009 | Kenmore 62622 Microwave Oven
The fan on our Kenmore microwave oven is not working.
My husband took the unit off the wall looked down into the fan and found a dead mouse keeping the fan from spinning. We removed the dead mouse cleaned up the area. Turned on the oven. The fan worked perfectly. Then he rehung the microwave.
Thanks!
Aug 18, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
FAN WONT SHUT OFF
My Kenmore microwave oven fan has been turning on and off, almost every hour. Sometimes 3 or 4 times in one hour. It's very random. Model No. 721-80593401 Serial No.503TA03208
Please help!!!
May 31, 2009 | Kenmore 62642 / 62644 / 62649 Microwave...
Kenmore 665 68610891- built-in 1998 model
Fan relay on circuit board stuck. Give it a tap (the relay), to free it up. Otherwise get the relay or driver transistor replaced. Easy fix. Take it to an electronic repair place, not the brand agent.(They,ll just replace the whole board).If this Item is under warranty you should not be wasting my time.:::Spiceweasel.au
Mar 30, 2008 | Kenmore 80809 Microwave Oven
Maytag MMV1153A Microwave Oven Logo
Top Maytag Microwave Ovens Experts
Michael Thomas
Michael Thomas
Paul Bade
Gerry Harvey
Gerry Harvey
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
