GE WJSR2070B Top Load Washer Logo
Question about GE WJSR2070B Top Load Washer
Change the timer - GE WJSR2070B Top Load Washer
1helpful
2answers
Do i need to power down to change the back up battery
If this is ordinary residential timer, you can replace battery without changing anything.
Just replace battery.
Most timers will hold some or part of the memory during battery changeover... frequently losing no programming if battery change is done quickly, and battery was not completely depleted, and timer is still functional.
If timer function is not restored after battery change, reset timer fully and then reprogram.
If battery change and reset does not work, then timer is probably gone bad.
Most modern timers have reset button, but some require a 2-button sequence to reset.
Other modern timers have a 'battery' but the battery is built into the circuit board and thus not replaceable ... it is rechargeable, like a capacitor ... but when it fails .. the timer needs to be replaced.
Timers with replaceable batteries are generally not functional after exposure to freezing temperatures for several day, but the non-replaceable type generally have wider tolerance for temperature variation.
http://waterheatertimer.org/How-to-troubleshoot-timers.html
http://waterheatertimer.org/Programmable.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Can i change the model T101P3 timer from 110 to 220?
1) Yes. Change clock motor from WG1570 to WG1573
Wiring is same as T102 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T102
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
2) If new pump motor is 2-speed, then converted T101P3 cannot handle 2-speed pump.
Use T106 timer, or T1906 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#2-speed
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html#pool
3) New T106 or T1906 timer mechanism will snap into T103P enclosure without changing boxes.
Any intermatic timer will snap into Intermatic enclosure.
Other brands of timer can adapt to Intermatic enclosure using Tork IAP adapter bracket.
Gldb957ab2-won't change cycles
Check the timer to make sure the wire to the timer motor did not come unplugged.
If all the wires to the timer are plugged in and you have power to the timer motor then it sounds like you have a bad timer
Parts For BMW
Dryer not turning on.........before I would change the timer setting and it would would work.......after a couple of weeks, when i change the timer setting it wouldn't turn on at all. Question is
Definitely sounds like a timer problem. Sears Parts Direct should have your part. The model # you supplied is incomplete to determine if you have a gas or electric dryer. Check the model # again and go to Sears page to find the correct part.
The self=adjusting wall switch timer does not go on as set but it goes off at the set time, I put in a new battery at the end of May but sometimes the Batt is flashing. The battery sure can't be...
1) Timer is not 100% identified.
Sounds like Intermatic ST01C or Ei600
Sounds like timer needs to be reset after battery change, and then reprogrammed again.
3) Open following links to help identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/ST01C-program.html#battery
4) If timer does not show on links above, add a comment with clear description of timer and buttons for possible identification and manual.
5) Most battery operated timers require 'reset' after battery change.
Manual usually says to replace battery and timer is ready to go again.
However, most timers lose functionality with battery change. That's why timer is reset, and then reprogrammed.
6) If functionality is not restored after battery change and reset, then timer has gone bad.
7) Intermatic timer has 1 year limited warranty, and there is not much that can be offered except buy next timer at local store. For example Utilitec 0192773 is actually Intermatic product. Sold at Lowes. If timer goes bad 2 years later, buy another one and return defect in new package.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
We need clear instructions for setting the timer
Woods makes several outdoor timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
ELEC. DRYER WON'T START
You could change the timer...that sounds logical.
Top GE Washing Machines Experts
Marvin
Marvin
Mike
David Shaub
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
