When the set powers off after pressing power try pressing the menu and input buttons on the set both in together and hold for 6 seconds to see if the power indicator will blink a two digit blink code which repeats a few times indicating a specific error. Let me know the blink code if any.
Probably your waste ink counter. Should be cleaned or replaced before resetting
but usually you can get away with resetting once. 1. Start with printer
OFF 2. Hold down RESUME and then hold down POWER 3. Release RESUME 4.
press RESUME twice, then release POWER 5. let green light blink until
printhead has finished moving. 6. Select functions below with RESUME, execute
with POWER
0 presses - green light - Test Print 1 press - orange light - EEPROM info print 2 presses - green light -
EEPROM initialise 3 presses - orange light - reset waste ink counter.
First try taking the inks out and the printhead and see if power stays on. If so you need a new printhead. the part number is on the side. If not, sounds like a bad power supply.
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
