Question about NetGear RangeMax Dual-Band Wireless-N Router with 4-Port Ethernet Switch
IPAQ RX3715 can't log on to home network
The iPAQ is an RX3715 and the router is Rangemax. It worked fine until I turned on my new iMac. The iMac got on the network no problem but now the iPAQ will not. In my mucking about now the WindowsME machine in the other room can't get on the internet either. Any thoughts?
Posted by idrankthekoo on
Anand Gupta
  • 1,272 Answers
Try upgrading the firmware on the router and then connect the IPAQ and computer to the wireless network
Posted on Jun 20, 2009
My Rangemax wireless wndr3000 is not working properly, though it has in the past. The problem seems to be that I'm hooked up to the wireless network (ex. I can print wirelessly), but with no internet....
Same situation here. Wired connection from modem works fine. I can also log in to the router via routerlogin.net. However, the router does not detect an internet connection.
1helpful
Hi I have a RangeMax - and it has always been working fine. Last week I couldn't connect wirelessly, so I reset. Nothing. Now I've tried connecting wired through the hub - still nothing. The power is...
Can you please check the signal strength of the wireless router.
If you can log into the wireless router management page and check for the erros if any inside the logs.
I just bought a Sony Bravia TV and am trying to connect it to the internet via my WPN824v2 LAN - it's not working and the LAN lights never light up on my router. Wireless connections are fine - even new...
I spent the last day trying to solve this, what worked was:
Home
Settings
Network
Refresh Internet Content
Wait (a while) until it Authenticates
Normal Internet service resumed :-)
Netgear wireless router wireless light won't light
Once \you reset your router, the router must be set up again in orser to use it wirelessly. Connect with CAT-5 cable router to computer, go to http://192.168.1.1 log in to router with name = admin and password left blank. Go into the Wireless section, set your SSID (Network Name) and whatever security you want to use. Write it down, do not forget, you should be back on line. Contact me if this does not work [email protected]
Can't connect to home wifi network
where are you, home, Starbucks, the airport?
at home this OLDThing only works with Old WEP encryption.
so go to your home router log in and turn on WEP.
most home are setup with WEP turned off, do to it is not secure now.(was cracked long ago) and for that reason is turned off.
1: turn on WEP
2:write down the passphrase used there and bingo.
Lost internet connection
If that Toshiba laptop is not in use do you still experience that problem?
You may change wireless channel in your router.
Do a firmware upgrade for your router as well.
Hope this helps!
Connecting a Ipaq RX3715 to a wireless router
First, you have to be sure your ipaq has wi-fi feature is on and you can check on network connectivity option for any wrong setup there. According to your information, your ipaq is not recognized by your router and I agreed that your router is working normally. Try to reboot your ipaq and be sure to get wi-fi to turn on and try to connect it again. I have my Dell Axim also used Windows Mobile like Ipaq and it connected easily with no issue. The message in your to show me that you need first to identify your ipaq before you you can get it to connect to your network. I hope this help.
Ipaq RX3715 hard reset
hard reset: Button 1 and 4 and press reset button with stylus
Can't open my home page
Try to soft-reset your iPAQ; depending on the model of iPAQ you have the soft-reset hole is located on the left hand side or bottom of your iPAQ; press the tip of the stylus into this hole to reboot your iPAQ.
Rx3715 battery power trouble
Did you check if the PDA was hot? My battery was totally dead one day when I picked my 3715 up, just to found out it was blistering hot (was turned off) and even the backup battery was empty. Running fine now after hardresetting it, but still...
NetGear RangeMax Dual-Band Wireless-N Router with 4-Port Ethernet Switch Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
