Re: 24" dell monitor swivels to vertical- can't get image...
You need to tell your system to do it or press the button on the monitor. Usually, only tablet PC's have the recognition software to do it automatically
If you go to the HP support website (hp.com/support) you can download the application for your monitor that automatically switches the resolution and orientation upon swiveling the monitor form horizontal to vertical or vice versa.
1. Try on another monitor to rule out VGA card. // If overclocked return to default values, disable automatic overclocking if selected in BIOS, check cooling
2. Try another cable, if both VGA and DVI connections exist try switching between them ( cables )
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
I had the same problem on both of my LP2417 monitors. It turned out that there was a swivel software installed that was causing the problem. I found it in my taskbar and it didn't work when trying to swivel the monitor so I went into my control panel, add/remove programs, found the offending software and uninstalled it. After a reboot I was able to control my monitor swivel with my built-in Windows desktop preferences.
I'm sorry I don't recall the exact software name (its been a few months) but it shouldn't be too hard to find.
you need to replace switching transistor 2SC5707 in the Power Inverter Board.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503.
If you can't get this item to work let me know, I can help
I have fixed a lot of these monitor with no problem.
Like I said last night cobra there is a vert shaper cap off the jungle/drive ic usually a smaller value and will check good but its bad. Or the b+ filter cap off the fly has caused sysmtoms like this as well. Good Luck
