A/c was working fine until 2 weeks ago, my 11 yr old carrier 3 ton compressor shorted out and tripped a/c breaker, I hired the company who did the original instalation replace the faulty unit with a 3 ton Goodman unit,it runs 10 minutes on and 5 minutes off continously , my electic meter shows I have used more Kwats in 10 days than I normally use in a month.everything worked fine before.my new thermostat is set at 74F,how many kilowatts should a compressor this size use under normal conditions?
I'm not sure of the kilowatts. The 10 min on and 5 off is telling me there is to much heat by the thermostat or you house needs more insulation. The new compressor is designed for more efficient run time. The other thing is the unit to big for your house? It should run 10 -15 min when low humidity is in the house. Otherwise longer if its pretty warm inside.
