Most tv's can be reset when you unplug them. Unplug the tv and let it set for about 30 min and plug it back in. This should reset the code to factory default of 0000.
To reset the pin code on your Grundig TV 32 GEH 6600B, you can try the following steps:
Turn on your TV and press the "Menu" button on your remote control.
Navigate to "Settings" and then select "Child lock" or "Parental control."
Enter the current pin code (if you know it) using the number buttons on your remote control. If you don't know the pin code, try entering "0000" or "1234".
Once you are in the parental control menu, select "Reset" or "Clear all" to reset the pin code.
Confirm that you want to reset the pin code by entering "Yes" or pressing the OK button on your remote control.
If this does not work, you may need to consult the user manual for your specific TV model or contact the manufacturer for further assistance.
U can't in most cases,that why they called a secret passwords codes.U only can tries this by unplug the converter box and replug it back 24 hours later.Go to parental control codes mode and resetting the mode,might resetting the mode and erase the secret passwords codes,only some models of boxes could do this,ur included don't know sorry.
Go to parental controls in system settings. When it asks 'Change
Parental Controls settings?' tap yes. When it brings up a numeric
keypad, tap the center button, "I Forgot". Next, tap "I Forgot" again.
Now you will be shown a screen with a number at the bottom (the
'inquiry number'). Go to http://wii.marcansoft.com/parental.psp on your
computer and enter this number in the field marked confirmation number.
Set the current date in your timezone and click get reset code. And
Voila! Your DSi is now parental control free!
CLICK HERE this link is for the site where you need to enter the code to get the master code once you have this you can then remove the parental lock
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the
parental code. You can either insert a restricted disc, or enter the
DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness
of the player. The lower the value, the more strict it will be. Either
increase the value to lower the restriction, or disable the lock
entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is
empty, and press the RESET button on the front of the Playstation 2. It
is imperative the tray is clear of any DVD or game for the unit to save
your settings.
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password. OR TRY THIS.. Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
Bill
