Last week it stuck on the final spin so I ran it thru another cycle. Now, my clothes don't dry even if I spin it more than once. I have it on high speed. It does go around but not fast enough? I don't know if it is something I should fix or if it will cost too much. All else works fine, but the spin/drain? Clothes are soaked...
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
SOURCE: Frigidaire GLTF2940FS...does not do a final spin/clothes wet
If water remains in the drum the unit will not go into the final spin.There may be a couple of reasons for your problem.
1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water.
2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. I believe the pump is about $60.00 and is accessible after removing the front panel under the door.
SOURCE: My clothes are still soaking wet after the final
there could be a problem with your belt being to loose. how ever i think the main problemis the motor is not turning or gearing up into the high side of the spin cycle.other problem may be the transmssion but i would check the motor first
SOURCE: Frigidaire front loader washing machine won't spin...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
