Question about Toymax Magnavox 37MF337B 37 in. LCD TV
I had my magnavox tv mounted to wall, but now I would like to put it back on the base and I can't figure out why.
Posted by Ricky Macias on
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
1helpful
Trying to figure out how to convert the base to a wall mount since it appears that it is set up to do this.
first get a wall mount kit. ikea sells them cheaply.
there should be 4 screw holes on the back of the screen. screws goes in there.
first drill 2 holes on the wall
mount the ikea kit using expanding bolt
then screw in the ikea kit on the monitor
just hang the monitor on the wall side.
but..... 15 inch is a bit smallish for wall mount... dont ya think?
2how to get around large base that sticks out too far to use a low profile mount to mount my magnavox 26MD357B/37 hdtv
Apparently you need some kind of MOUNTING SCREW EXTENSIONS to mount your tv to the wall.
You will need to contact Philips Customer Service at 1-800-705-2000 to order them.
See page 5 of your tv's USER'S MANUAL at the following link:
http://download.m4c.magnavox.com/files/2/26md357b_37/26md357b_37_dfu_aen.pdf
Good luck and please comment back if this was helpful.
4helpful
Remove base to wall mount
Place the TV face down on cushioning. There are four short hex head screws that hold the TV to the stand. There are two on each side of the mounting point (close to the bottom of the TV). (Turn counter-clockwise to loosen.) Next slide the base down from the bottom of the TV. The appropriate sized hex key was supplied with the TV (and the base was installed). If you want to, you can unscrew the support post from the base - it has 4 long hex head screws. This will let you put the base parts into an appropriate container for storage.
For a clear picture, see the manual for installing the base and work the steps in reverse. See here for a copy of the manual: http://www.managemylife.com/mmh/owner_manuals/search?query=LC46SB54U+ .
To put on the wall mount, you will need to remove the covers from the 4 mounting locations on the back of the TV and use the screws from the wall mount bracket kit.
I hope this helps.
Picture remains for few seconds then screen goes blank, sound remains on
I had this problem on my 42" Philips LCD. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Screen goes blank after about 10 or 15 minutes. There's still sound coming through. Picture comes back on if you turn the tv off & back on again. Any suggestions? (Sansui HDLCD2200 LCD TV) Thanks.
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
Whilst watching tv after 10 to 15 min screen goes blank but sound ok ,when u turn tv off then back on u get pitcure for about 10 minthen goes off again
1helpful
3answers
LCD TV screen goes blank with sound still on
Have the inverter board checked for cold solder joints, this television is notorious for bad connections on the small transformers on the inverter, buy the way the inverter is the board that lights the lamps.
Thanks please leave comment
3answers
Akai PDP42Z5TA 42 in. Plasma base removal
If you ever get the base off, I'd like to buy one.
Toymax Magnavox 37MF337B 37 in. LCD TV Logo
Top Toymax Televison & Video Experts
Ekse
Tom Chichester
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
