Water drains very slowly, there is no spin and water remains.
SOURCE: machine not taking the last fastest spin to drain the water.
the problem is that your machine is not emptying the water fast enough as the machine takes in a good deal more water on the rinse. clean the filter.
SOURCE: Washing machine doesnt seem to be draining or spining properly
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
SOURCE: not spining
Check for spin control safety switch under cover. Check belt is good & not slipping, replace belt.
