Ariston ARWDF 129 NA 23" Washer-Dryer Combo with Electronic Logo
M
MARILYN GEORGE Posted on Mar 02, 2014
Front load Whirlpool washer will not fill with water this happened once while under warranty and it was some kind of senser that was out I think it is the sensor again but do not know what sensor
Graeme White
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Mar 02, 2014
Graeme White
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
3852
Points
11
Hi, this could be a faulty door lock. If the washer is put on a spin cycle does it burst into life? If yes then door lock is fine. If no movement then this may just be a bad connection on door sensor (clean contacts) or it may need new door lock.
Water slowly runs in washer when it isn't on
dirt or faulty inlet solenoid diaphragm
simple fix is to turn the tap off at the wall when finished
My whirlpool front load keeps cycling without the water filling.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Water fills tub when off
You have kinds the opposite problem as these tips...there is dirt in your fill valve...
heatman101
The drum fills with water when not in use.
You have kind of the opposite problem of these tips... the soleniod valve has dirt under it and will not shut off tight...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
My Whirlpool duet washing machine is collecting water in the tub after laundry is long done
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Kind of the opposite of these tips... your fill solenoid has dirt in it and it won't shut off...
heatman101
2helpful
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
3helpful
Duet whirlpool washer mysteriously floods the floor when we are gone. It happens when door is closed or open. Even when empty and off. 4 times now!
I had the same problem, found it at about 2 am. No fun. Pretty easy fix. The part on the back of the washer where you screw in the water lines in needs replaced. Its been 2 years but I think it only took about 30 mins to fix once I had the part. Remove the top of the washer (couple screws in back) The part that the hoses screw into has a wire that goes to it that opens/closes the vaule when it needs water, its not closing all the way and water is continuing to fill. Good luck, think the part was about $50 or so. I would shut off the water at the wall in between washings until its fixed, and when on vacation. The hoses always have water in them if the. good luck
1helpful
Water backs up into washing machine after washing a load.
check your drain hose and drain pipe,if not that then i think your inlet water valve is not closing all the way,try it on cold only see what happens,then try on hot only see what happens,let me knoe what you find-mike
Top Ariston Dryers Experts
john h
Are you an Ariston Dryer Expert? Answer questions, earn points and help others
