I need a operating manual for this remote control
Http://files.remotecentral.com/view/976-1173-1/samsung_aa59-00356.html
Try the above link, to download the manual.
Gopakumar Gopalan Google
SOURCE: tv won't operate off remote control
Unless you had the remote tested by Samsung, the test isn't comprehensive; it will only tell if the remote is putting out infra-red of some kind, that type of tester cannot determine if the codes are correct or complete.
The only true test would be one in which you had a second TV or a second, known working remote. Even using an oscilloscope with an infra-red detector wouldn't help unless one had the specific code sequences available, it would only appear as a pulse train.
SOURCE: need control code, to operate dvd samsung
Yes. I found the code. To operate Samsung HT-Z 310 with a remote control of Samsung TV, You have to turn off DvD, and then select Dvd on the remote(press the dvd button), press SET on YOU
remote control, input the CODE(020). For different Samsung dvd. you can try.codes from 000-to 080. The DVD button must blep three times. After that swich on Dvd. Enjoy....
