Question about Mag Innovision InnoVision XJ 717 Monitor
Sony videoscope XBR - Side by Side screens can't change it back.
I hit something on my universal remote and my TV(sony videoscope XBR) went to Two smaller screens - Side by Side. One on the left was static and the one on the right was my cable programming. I have no idea what I pushed and I don't know how to get it back to One screen. I've tried everything I can think of, please help me
Posted by dzieg224 on
Anonymous
  • 79 Answers
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
Posted on Jun 11, 2009
  • dmassaf Apr 13, 2011
    I had the exact same problem and tried using the PIP buttons but they don't work. I know that I have it hooked up but I can't get my tv to go back to the way it was. Is there any other way to get rid of this? Help me please.
Manual for Sony videoscope XBR, model # KP-53xbr35
Hi csp,
Welcome to FixYa.
My name is John.
I will be assisting you with your issue.
You can get one here. www.manualsonline.com .
Thanks for choosing FixYa.
John
Jan 03, 2011 | Televison & Video
I have a universal remote and need the code for a Sony Videoscope XBR projection tv
I don't know if all codes are the same. Comcast Cable gave me a list of codes for their universal remote for their motorola cable boxes. For Sony tvs it says either 0000 or 0111. I still use all 7 of my remotes. Universals are basically only good for power and volume. I need the other remotes handy to enjoy the other functions of my system! Anyway, hope this works 4-u and that you get better use out of it than me.
Sep 01, 2009 | Sony KP-51HW40 51" Rear Projection...
Can't turn off PIP on Sony XBR videoscope TV
Hit the set up button on the TV.
You'll see options to change the language. The last option is to put the TV in "Demo Mode."
Put the TV in Demo mode, when the first screen appears, "Welcome to...." the PIP will disappear.
Hit exit before the screen moves to the "Menu." If you miss it, watch the demo once--it will restart--and hit the exit button the next time you see the "Welcome to" message.
I just did this and it worked for me - i hope it works for you.
Apr 14, 2009 | Televison & Video
TV has sound no picture, Sony Videoscope xbr
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
Thanks,
Dan
Feb 10, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony Videoscope XBR 53
This is a convergence problem. Look in the back for a couple of large black ICs attached to a heatsnik. These should be marked STKxxx. These are the convergence ICs and either have bad connections or are defective. If you can solder, try resoldering the pins on these ICs. If that fails to resolve the problem, replace the ICs. There may be other parts that need to be replaced as well. I'll look up your model to find the other parts to check. The convergence board as an assembly, I believe, is no longer available. The parts that you require are available.
Dan
Sep 18, 2008 | Televison & Video
Sony Videoscope XBR tv
This is usually a convergence problem.. Could you update this with the model number please. That will allow me to give you some specifics about what could be wrong and how to fix it.
Dan
Apr 18, 2008 | Mag Innovision InnoVision XJ 717 Monitor
Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
TV not working- Sony Videoscope XBR
Might be a bad High Voltage Distribution block, you will want to call a trained tech to diagnose something a little knowledge can be dangerous with stuff like this.
May 19, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Mag Innovision InnoVision XJ 717 Monitor Logo
216 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
ThaMp3Doctor
ThaMp3Doctor
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
